First bolt-ons for 91 vette?
Old Oct 27, 2003 | 10:47 AM
VaderWS6's Avatar
VaderWS6
5th Gear
Default First bolt-ons for 91 vette?
My dad has a 91 vette 6 spd convert. , and I was curious what you guys would recommend for a good +25hp with simple bolt-ons. Thanks.
Old Oct 27, 2003 | 03:14 PM
robertpel9's Avatar
robertpel9
Default Re: First bolt-ons for 91 vette? (VaderWS6)
I have a 91 vert too:)
The biggest bang for my buck (zero dollars) was advancing the timing to 10 deg from 4 (factory setting is 6) it was like night and day. Other things to do
1)Toss the frisbee (do a search)
2)Free flow exhaust
The L98 is limited in the intake department if you are looking to spend bucks thats the way to go with a intake/headers combo. I just played with gears and the cheap stuff and it is plenty fast. Good luck!!
Old Oct 27, 2003 | 03:34 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
For around 25 hp gain, try the low cost & "free" mods:
-toss the "frisbee" from the front of your water pump pulley, 10chp
-K&N air filter with cut lid, 10chp
-160deg stat & fan switch, 10chp
-cut-back spark plug ground electrodes (details on my site, see sig.below), 8-10chp
-AFPR for tuning fuel flow at WOT, no chp gain per se, but a vital tuning aid if your doing futher mods.
Indeed your L98 will respong well to the addition of a free flowing exhaust, if your dad will tolerate the increased sound level:
-hi flow cat & cat back
-LT headers or mandrel-bent front Y
These should net you 15-25chp gain, depending on the path chosen.
For results on some other mods to that L98 check out the table on my site.
To First bolt-ons for 91 vette?
