Electrical experts please help!
Old Oct 27, 2003 | 11:22 AM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
Default Electrical experts please help!
My car has issues...please help! :confused: Here is a link to the long story: http://digitalcorvettes.com/forums/s...&threadid=5018 :confused:
Old Oct 27, 2003 | 12:46 PM
bogus's Avatar
bogus
Default Re: Electrical experts please help! (yoslambo1@cs.com)
you have found the problem... it's in the radio circuit... now, the question is WHERE in the circuit.
You need a volt meter and the helms manual. Then start testing every single wire in the circuit. It will mean removing convolute and electrical tape.
you have a bare wire somewhere.
Old Oct 27, 2003 | 12:55 PM
yoslambo1@cs.com
Default Re: Electrical experts please help! (bogus)
Bogus...What if I remove the radio & run all new wiring for it? :confused:
Old Oct 27, 2003 | 12:56 PM
J Z06's Avatar
J Z06
Default Electrical experts please help! (yoslambo1@cs.com)
that sounds like a fine idea....original wiring in a near 20 year old car, some of it could be frayed or chafed.
nice when you can almost solve your own problem eh?
Old Oct 27, 2003 | 12:59 PM
yoslambo1@cs.com
The ignition/starter is wired to the radio circut? :confused:
Old Oct 27, 2003 | 01:00 PM
yoslambo1@cs.com
Default Re: Electrical experts please help! (Jay 383)
Bogus...What if I remove the radio & run all new wiring for it? :confused: that sounds like a fine idea....original wiring in a near 20 year old car, some of it could be frayed or chafed.
Jay, I hope it is that simple? :confused:
Old Oct 27, 2003 | 02:11 PM
yoslambo1@cs.com
Even though my mechanic says its not the starter I BELIEVE that it is. If my starter was bad would jumping the cylonoid with a screwdriver be possible? My mechanic says if I can jump the cylonoid that the starter is not the problem? :confused: :skep:
Old Oct 27, 2003 | 02:22 PM
dwestsr's Avatar
dwestsr
your mechanic could be right about the starter. it is probably a bad solenoid not a bad starter. also you may have more than one problem. i would still check out that radio circuit. if you don't fix that , you could have an electrical fire and lose the car.
Old Oct 27, 2003 | 02:28 PM
bogus's Avatar
bogus
Default Re: Electrical experts please help! (dwestsr)
You need to get a Volt meter and start to dig into the main harness.
I hate to say it, but you might have to pretty much take the dash apart.
WARNING: I would not leave the battery connected until you find this problem!!!!!
Old Oct 27, 2003 | 02:30 PM
yoslambo1@cs.com
I am gonna check the radio circut....but if I change the starter it might solve the problem? :confused:
Old Oct 27, 2003 | 02:57 PM
FD2BLK's Avatar
FD2BLK
I think your mechanic gave you some good advice. Next time the problem hapens put a test light on the purple starter wire and see if you are geting 12V. If you are then it is the starter if not the problem. You have a lot of diferent electrical problem ocuring and probably have a wire shorted some where. I am wundering about the new colum you installed, how long after you installed it did your problems start?
Old Oct 27, 2003 | 03:23 PM
yoslambo1@cs.com
Default Re: Electrical experts please help! (84LT1)
That is exactly what he told me (purple wire)....Problem is it wont not start now! I installed my column like 4 months ago....I dont think it is the problem? :confused:
Old Oct 27, 2003 | 03:25 PM
yoslambo1@cs.com
with the key on or just check to see if there is power there at all? :confused:
Old Oct 28, 2003 | 04:18 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
ttt
Old Oct 28, 2003 | 04:23 PM
yoslambo1@cs.com
Default Re: Electrical experts please help! (oldace84)
ttt
Thanks Tony! :thumbs: I put the car away for the winter today......I will worryabout my electrical issues then. :smash:
To Electrical experts please help!
