front Y pipe
Old Oct 28, 2003 | 09:56 PM
89blkvet's Avatar
89blkvet
Default front Y pipe
I have an 89 with the pre-cats. I am thinking about buying the Y pipe without the pre-cats. Other than the smog check I have to deal with, are there a lot of benefits from removing the pre-cats. My car has a new engine with a "Computer freindly Cam", shaved heads, 30 thousands over block, 160 stat, 50 series flo's, open air box. Also I am thinking of getting a 52mm throttle body. Anysuggestions?? Thanks
Old Oct 28, 2003 | 10:22 PM
1990CORVETTE's Avatar
1990CORVETTE
Default Re: front Y pipe (89blkvet)
Welcome to the Forum
It is my understanding that doing away with the pre-cats, you will gain HP, but you will loose bottom end TQ...
Old Oct 28, 2003 | 10:25 PM
Mad-Mic's Avatar
Mad-Mic
i noticed a good difference in the butt dyno :)
Old Oct 28, 2003 | 11:15 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
When I did a 2 1/2" mandrel-bent SS front Y along with a hi-flow 3-stage cat and hi-flow cat-back I picked up ~18chp and had no low end losses.
If you want a good 52mm TB go with the AS&M unit; it is a quality piece. I have the BBK and it was a PITA go machine it to accept the front bellows.
Old Oct 28, 2003 | 11:16 PM
TA's Avatar
TA
Replace the 2.25" stocker with a 2.5" mandrel bent piece and you should see a nice gain. I wouldn't be concerned with losing lower end torque. Although my car still has the stock exhaust manifolds, the rest of my exhaust flows pretty freely (no cats) and it gets out of the hole better than it ever did :yesnod:
Old Oct 29, 2003 | 05:21 AM
DON M's Avatar
DON M
If you can get by the visual check during the emissions testing it is a great mod.
There are 49 state legal kits that eliminat the pre-cats but the Republic of Kalifornia doesn't recognize them.
Welcome to the Forum :seeya
Old Oct 29, 2003 | 06:52 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
I did that to my 90 and if anything it seems to have more power than before. It could be though that it feels that way because my pre cats were falling apart and could have been partly blocking the exhaust.
Old Oct 29, 2003 | 08:48 AM
TIMSPEED's Avatar
TIMSPEED
Also I am thinking of getting a 52mm throttle body. Any suggestions??
Yes, first off, don't bother buying a 52mm throttle body until you're Super or Turbo Charged...
As for the PreCatLess Front Y-pipe, it's best to order mandrel bends and have a shop custom make you one. :)
Old Oct 29, 2003 | 09:36 AM
Caboboy's Avatar
Caboboy
Welcome to the forum from 2 or 3 miles over :D :seeya
Old Oct 29, 2003 | 11:05 AM
NORMSTOY 89's Avatar
NORMSTOY 89
I am thinking about doing the same thing. Can you still install the O2 sensor in the Y-pipe?
Old Oct 29, 2003 | 11:51 AM
joecaver's Avatar
joecaver
Default Re: front Y pipe (NORMSTOY 89)
On the one I got from Ecklers you could.
Old Oct 29, 2003 | 09:35 PM
89blkvet's Avatar
89blkvet
Default Re: front Y pipe (joecaver)
Thanks for all the great advice. It looks like I will get the front Y pipe, minus the pre-cats, and install myself. I am still thinking about the 52mm throttle body
Old Oct 29, 2003 | 09:44 PM
69vetteracer's Avatar
69vetteracer
Beware, the bigger throttle body means less velocity, means less torque. You will feel it in the seat test. However, you will rpm quicker in the upper torque curve. Not recommended unless you have plenty of other mods. :chevy
To front Y pipe
