What is a plenum and what does it do?
Old Oct 30, 2003 | 01:40 AM
zoopoptung's Avatar
zoopoptung
Default What is a plenum and what does it do?
I'm wondering what the Plenum is, noticed a cover for it in the mid america catalog. Plus I noticed if you get a 58 mm throttle body require port matching of plenum? I'm so confused.
Old Oct 30, 2003 | 09:55 AM
scorp508's Avatar
scorp508
Default Re: What is a plenum and what does it do? (zoopoptung)
The plenum is pretty much the "box of air" on top of your intake manifold. On an LT1 it is the shoebox looking thing which is behind the throttlebody. The air is sucked into the plenum through the TB and then evenly distributed to the 8 runners in the intake manifold to each cylinder.
On an L98 it is the thing that the 8 curved runners are coming out of on top of the engine.
Old Oct 30, 2003 | 09:59 AM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: What is a plenum and what does it do? (scorp508)
Well said.........
:thumbs:
Old Oct 30, 2003 | 10:29 AM
86_RedRider's Avatar
86_RedRider
Cruise-In V Veteran
St. Jude Contributor '03 & '05
Default Re: What is a plenum and what does it do? (edsalinas)
good description. in general, a plenum is where an enclosure of air has higher pressure then the outside air. a duct for heating and ventilating or in our case the big boxything on the top center of our cars.
Old Oct 30, 2003 | 10:31 AM
86_RedRider
Cruise-In V Veteran
the reason you would need to port the plenum is because the opening of the TB is larger then the plenum opening that it attaches to.
Old Oct 30, 2003 | 10:43 AM
Steel Blue 91's Avatar
Steel Blue 91
Affectionately known as "the Lobster". :jester
Old Oct 30, 2003 | 01:17 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: What is a plenum and what does it do? (Steel Blue 91)
I prefer to call it the TPI Alien facehugger! :thumbs:
Old Oct 30, 2003 | 07:05 PM
vetracer's Avatar
vetracer
Default Re: What is a plenum and what does it do? (onedef92)
But few intake setups LOOK cooler than an L98 IMO - I'll never forget how cool I thought it was when I first saw it in '85 on my brother's (and later mine) Corvette. Instant tire smoking throttle response. GM was still using carbs up until '82 and then it was the crossfire. Had an '82 Trans Am with that, pretty lackluster on the 305. Anyway, getting back to the subject...
My race motor builder also calls the opening below the carb in my Edelbrock Super Victor a "plenum".
Old Oct 30, 2003 | 08:01 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: What is a plenum and what does it do? (vetracer)
Very likely, because... it IS.
Old Oct 30, 2003 | 08:22 PM
zoopoptung's Avatar
zoopoptung
Default Re: What is a plenum and what does it do? (CFI-EFI)
that clears things up, thanks guys. would you suggest changing the throttle body, probably a 52mm when I do exhaust, cutout airintake lid and headers? if so, what order should I go in? another thing...what about the mass airflow sensor?
Old Oct 31, 2003 | 03:21 PM
Flame Red's Avatar
Flame Red
Default Re: What is a plenum and what does it do? (86_RedRider)
Funny, I just replaced my 52mm TPIS TB because it sucked :lolg: with a 58mm BBK. I guess I wore out the TPIS as the spring would not always completly close the TB and I would end up with a really high idle.
The BBK bolted right up and I did not have to port the TB openings. The 58mm TB went to WOT without hanging up or rubbing.
Just lucky (for once) I guess? :hurray:
Old Oct 31, 2003 | 03:41 PM
vetracer's Avatar
vetracer
Default Re: What is a plenum and what does it do? (Flame Red)
I had one I got new from GM and it was a defective POS. I got a replacement and it worked fine. These TB's are very tempramental IMO.
To What is a plenum and what does it do?
