Air Mixture door adjustment
Mine works except that it takes a couple of minutes to go to cool
when "cold" is selected. I heard there was an adjustment.
Anyone heard of this?
see that rod coming in from the left from iside the car -not the flat from the door-? That is from the vacuum controlled bladder/motor. If there is any adjustment, it's in the plastic clip(centered in the yellow circle) but I doubt it. Sounds like you have weak vacuum signal in the system.
[Modified by 89 Paul in Cal, 7:07 PM 10/30/2003]
