Sparkplugs with resistor in them?
Old Oct 30, 2003 | 06:19 PM
MrNuke's Avatar
MrNuke
Default Sparkplugs with resistor in them?
What are these? And why woudl they be used?
Just curious as I tried to put a set of Autolite AR13 racing plugs into my vette and it caused an electrical nightmare. Swapped them back to stock ACDELCO 1's and everything is back to normal.
Old Oct 30, 2003 | 06:36 PM
69vetteracer's Avatar
69vetteracer
Default Re: Sparkplugs with resistor in them? (MrNuke)
I believe that all plugs are now resistor. They came about years ago to replace the solid core plugs as a radio suppression measure. Same with the plug wires. Champion used an R in the number J12Y became RJ12Y. Same with Delco. :chevy
Old Oct 30, 2003 | 06:47 PM
MrNuke's Avatar
MrNuke
Default Re: Sparkplugs with resistor in them? (69vetteracer)
So hwo come an AR13 racingplug would not work in my vette?
The ones Im using now (ACDELCO) are not resistor types. They are about 3/4 year old.
Old Oct 30, 2003 | 08:08 PM
87NassauBlue's Avatar
87NassauBlue
:iagree: Yep, back in the old days of non resistor plugs, the plug wires also had copper cores. That was before we were running such high ignition voltage. If you run that stuff now, you will have a lot of EMF and it will interfere with your radio. I would think it might even goof up your ECM if it were bad enough.
Old Oct 30, 2003 | 10:36 PM
jfb's Avatar
jfb
Did you install plug wires that are not resistance wires? If so, then non resistor plugs will cause ignition interference in your radio.
Old Oct 30, 2003 | 11:16 PM
MrNuke's Avatar
MrNuke
Default Re: Sparkplugs with resistor in them? (jfb)
Here is my other thread about this.
http://forums.corvetteforum.com/zerothread?id=681901
I basically installed Autolite AR13 Racing plugs int he car, car started hunting for idle and stalling, the LCD display started flashing all randomly, my Digital FP gage was flashing on/off randomly too.
Swapped my stock ACDELCO 1's back in and everything is back to normal..
The ACDELCO's have no resistors in them (no 'R') but the AR-13 has a resistor I've looked up.
Old Oct 31, 2003 | 12:20 AM
J Z06's Avatar
J Z06
glad everything worked out ok.
now let that thing RIP on the drag radials....remember, good burnout, keep an eye on the mirrors, when you see smoke, roll out under power. :smash: :thumbs:
To Sparkplugs with resistor in them?
