350 Chevy Question
Old Nov 2, 2003 | 09:54 PM
VettBrat's Avatar
VettBrat
Default 350 Chevy Question
What is the difference between a Corvette 350 and a "regular" 350? My Vette is a 1986. I was looking to replace the valve covers and maybe the cam, but am totally confused as to what will work. Most of the parts catalogs I look at list cams and valve covers for 1986 Chevrolets, but don't include Corvettes?? :confused:
Old Nov 2, 2003 | 10:07 PM
nonetooclose's Avatar
nonetooclose
Default Re: 350 Chevy Question (VettBrat)
As far as I know there is no appreciable difference between a normal 350 and a vette 350 until the aluminum heads were introduced. One of the major advantages regarding these cars is the 350 and the interchangability and massive amount of upgrades for them.
You will have no problem with the valve covers or cam for your year of vette.
Richard
[Modified by nonetooclose, 3:08 AM 11/3/2003]
Old Nov 2, 2003 | 11:30 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: 350 Chevy Question (nonetooclose)
You have to be careful with valvecover to wiper-motor clearance on the vette, as well as valvecover to bracketry clearances on the front of the covers.
Old Nov 3, 2003 | 12:21 AM
vader86's Avatar
vader86
86 has a flat tappet, not hydraulic cam, so be sure to check
and you do have to worry about clearance for the valve covers, but unless you got some really big valve covers it shouldnt really be a problem
Old Nov 3, 2003 | 01:12 AM
CFI-EFI's Avatar
CFI-EFI
Default Re: 350 Chevy Question (vader86)
Huh ??? When did Chevy go back to solid lifters?
RACE ON!!!
Old Nov 3, 2003 | 05:24 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: 350 Chevy Question (CFI-EFI)
RACE ON!!!
:withstupid: :confused:
He must've typo'd.
Old Nov 3, 2003 | 07:07 AM
C10 JDR's Avatar
C10 JDR
Default Re: 350 Chevy Question (CentralCoaster)
:iagree:
Prob'ly means flat hydraulic, not roller.
Old Nov 3, 2003 | 12:47 PM
CFI-EFI's Avatar
CFI-EFI
He must've typo'd.
Right! And, boy am I glad I've never done that. :rofl:
Usually, if you turn the page, you'll find the Corvette parts. The parts are the same, but they come with "Corvette" pricing.
On the valve covers. I forget when they went to the centerbolt covers. All centerbolt covers fit all centerbolt style heads. Whether they're on a Corvette or not. The same is true of the perimeter bolt covers. Non stock covers may interfer with other under hood items. Tall covers will likely hit the wiper motor. Check carefully under your hood for items that may interfer, and contemplate whether you may want to move or make adjustments for clearence.
With cams, it is even easier. Roller or flat tappet, is all you have to know. The name "Corvette" poses NO problems, here.
Good luck, abd...
RACE ON!!!
To 350 Chevy Question
