Rattle in rear targa mount.
Old Nov 4, 2003 | 12:00 PM
yellow86v's Avatar
yellow86v
Default Rattle in rear targa mount.
I have been debugging my car since getting it back from the paint shop, but i have a rattle that seems to be coming out of the rear targa mounting area when the roof is off, and I see nothing loose on the outside.
Old Nov 4, 2003 | 09:05 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Default Re: Rattle in rear targa mount. (yellow86v)
For almost two years I was chasing this same sound (although not with very much effort) It turned out that the front guidepin was loose and flopping around when the top was in the hatch.
Old Nov 5, 2003 | 01:14 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Its probably the torx bolt used to fasten the top. If i remember correctly i believe there is a gap between threads on the torx bolt so you can back it off enough to remove top yet leave the bolt in the bracket. It could be just ratteling in that gap. :cheers:
Old Nov 5, 2003 | 02:08 AM
ENGINE TROOP's Avatar
ENGINE TROOP
Look in tech tips for a way to fix this
To Rattle in rear targa mount.
