Solid roller cam questions
Old Nov 4, 2003 | 06:02 PM
Ray383's Avatar
Ray383
Default Solid roller cam questions
What are the advantages/disadvantages to running a solid roller cam? I know the valves have to be adjusted every 5k or so, but that is about 2 years of driving for me. I have a new 219 cam, but I have an 86 4 bolt block and don't want to spend $400+ on lifters. Any advice is welcome.
Old Nov 4, 2003 | 06:24 PM
AS84's Avatar
AS84
Default Re: Solid roller cam questions (Ray383)
In the high rpms hydraulic rollers build up alot of tension and start to eat a small amount of hp. The solid roller will not do this, therefor will rev alot higher. If you went with a set of shaft mount rockers (depending on how hard you drove it) you could get many more miles out of an adjustment.
Old Nov 4, 2003 | 06:30 PM
Ray383's Avatar
Ray383
Default Re: Solid roller cam questions (AS84)
I'm really not the least worried about the adjustment thing. I'm just trying to cram every last $ and hp out of my buildup.
Old Nov 4, 2003 | 08:28 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
they make more power too :D :cheers:
Old Nov 5, 2003 | 07:48 PM
ncChris's Avatar
ncChris
Default Re: Solid roller cam questions (CORKVETTE1)
i just put a wild "comp" solid roller in mine..came out like a blaze oif glory and then toned down. Realized the solids were setting off the knock sensor.. u gotta have it programmed for that. Make sure you have the right springs too... A solid sounds neat
Old Nov 6, 2003 | 09:37 AM
LT4POWR's Avatar
LT4POWR
http://www.speeddemonmotorsports.com...onversion.html
Old Nov 7, 2003 | 09:19 PM
Ray383's Avatar
Ray383
Default Re: Solid roller cam questions (LT4POWR)
Thank you!
Old Nov 7, 2003 | 09:58 PM
No Go's Avatar
No Go
Default Re: Solid roller cam questions (ncChris)
ncChris: What are the specs on your Solid Roller Camshaft? Looking to do this move in near future.
Old Nov 7, 2003 | 10:02 PM
tpi 421 vette's Avatar
tpi 421 vette
Default Re: Solid roller cam questions (No Go)
For a maximum effort engine... a solid roller is the way to go.
Old Nov 10, 2003 | 10:00 AM
ncChris's Avatar
ncChris
Specs are: 242-248 .609-.613 12 lobe seperation
AFR heads long tube headers w 3" exhaust
electric water pump ( this is a real rwhp booster)
8000rpm shift in 1st and 2nd,,,,, 7600 3rd - 4th
Keep in touch and let me know how the project works out..,will be happy to give you any assistance............. Chris
To Solid roller cam questions
