New shocks makes body higher
Old Nov 4, 2003 | 06:15 PM
Trey96LT1's Avatar
Trey96LT1
Default New shocks makes body higher
Just installed some new kyb shocks all around and now the car is about a inch or so higher. Is this normal or did something go wrong?
Old Nov 4, 2003 | 06:18 PM
BowTieBlood's Avatar
BowTieBlood
Default Re: New shocks makes body higher (Trey96LT1)
probably where your car SHOULD be :cheers:
(that's my guess anyway :yesnod: )
Old Nov 4, 2003 | 06:27 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Have you driven the car after putting the shocks on?
Old Nov 4, 2003 | 06:32 PM
BobMachus's Avatar
BobMachus
When I replaced the shocks on my 88 the ride height rose at least an inch and a half. The ride was much, much better as the shocks I removed were the original 15 year old, 67k mi shocks. It looked too high to me so I bought a lowering kit.
Old Nov 4, 2003 | 06:39 PM
vader86's Avatar
vader86
It is possible to raise the ride height with new shocks, which indicates your bushings and other components are well worn.
Old Nov 4, 2003 | 10:29 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: New shocks makes body higher (Jeffvette)
:iagree:
yeah drive it around some and let everything settle, then form an opinion on if it'stoo high, my guess is that it will be slightly higher just because they are new.
Old Nov 7, 2003 | 06:19 AM
FC2000's Avatar
FC2000
Default Re: New shocks makes body higher (Mr Mojo)
Shocks will not hold the car up to a higher ride height, the springs do that.
(take any shock not installed and with a little muscle you can compress it by hand)
There is something else amiss i.e. suspension bind or as stated previously worn bushings. :yesnod:
To New shocks makes body higher
