Headers glowing red
Old Nov 9, 2003 | 02:27 AM
B84RADR's Avatar
B84RADR
Default Headers glowing red
My Hooker Headers were glowing red while I was trying tune the car's PROM. This means I'm running rich, right? Like gas is burning in the headers still?
The guy that was with me was trying to convince me I was running too lean.
Thanks,
Shayne
Old Nov 9, 2003 | 04:15 AM
pcadams135's Avatar
pcadams135
Default Re: Headers glowing red (sspackman)
it sounds as if it is burning up in the headers it would mean to me to rich.
Old Nov 9, 2003 | 06:08 AM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Check your ignition timing. Late or retarded spark could also cause gas to burn in the headers instead of the combustion chambers.
Old Nov 9, 2003 | 06:55 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Headers glowing red (Mez)
:iagree:
the late timing scenerio is more than likely the culprit now a cloged cat can also do it so if you have no cat then its probally late timing :cheers:
[Modified by CORKVETTE1, 6:58 AM 11/9/2003]
Old Nov 9, 2003 | 07:00 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
Default Re: Headers glowing red (CORKVETTE1)
super lean will burn hotter than super rich look at a egt meter when the egts go up it means lean mixture when its rich it gos back down
Old Nov 9, 2003 | 09:41 AM
Strick's Avatar
Strick
:iagree: This was the way you judged the timing on old 283s back when Moses was a private. Retarded-hot exhaust-not much acceleration, advanced-hot intake-better acceleration-hard to start-good chance of "ping"
Old Nov 9, 2003 | 10:53 AM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
If the headers are glowing red, you're definitely running too lean. I remember rebuilding a Holley 650 double pumper 25 times in one evening. Apparently there was a piece of dirt in there somewhere and the headers were glowing so hot red, you could stick a pencil in the headers and it would melt into it and then you could pull it out... the headers were that hot. I had to rebuild it one more time and finally got rid of any trash.... everything was fine.
You could have other culprits causing it to run lean (eg. cats, timing, etc, etc) but glowing headers is definitely lean.
Mark
Old Nov 9, 2003 | 11:36 AM
CFI-EFI's Avatar
CFI-EFI
Default Re: Headers glowing red (C4 Newbie)
Mark
"Cat, timing, etc, etc," Do NOT cause it to run lean. Those can be causes for it running HOT, and the headers glowing, but they don't affect the fuel MIXTURE. A lean mixture DOES burn hotter, as pointed out above with the EGT example, but it isn't the ONLY possible cause of headers glowing. My engine runs very rich. In an attempt to pass a smog test, we jacked the timing around. With retarded timing, the rich mixture was burning in the exhaust manifolds and made them turn red.
The statement, "glowing headers is definitely lean." is not true. It CAN be lean, but lean is NOT "definitely" the cause.
Shayne, The first thing I would do is check my timing. Then check your integer and BLMs for indications of rich or lean mixture. An A/F guage would be the best way to check the mixture. Good luck, and...
RACE ON!!!
[Modified by CFI-EFI, 9:46 AM 11/9/2003]
Old Nov 9, 2003 | 01:50 PM
DieL's Avatar
DieL
Default Re: Headers glowing red (CFI-EFI)
like this..
[Modified by DieL, 12:51 PM 11/9/2003]
Old Nov 9, 2003 | 02:47 PM
B84RADR's Avatar
B84RADR
Wow thanks a lot for all of the quick responses.
There are a couple of things I can tell you for sure. One, the timing is right at 6*. No question about it. The spark advance tables are also the stock ones from GM that I've been testing with.
I got my hands on an emissions probe with a friend at a local shop.
I tried leaning out the fuel pulse width in TunerCat some more and my idle HC's went right through the roof, I mean completely off the chart. They were burning your nose and giving you a headache. At 2500 RPM though, they came way back down to acceptable ranges. It seemed the leaner I went, the higher the HC's went. BUT we could DEFINITELY smell gas. That tells me we're running rich. But that's an assumption
I was going to go this morning and take the 30# Accel fuel injectors out and put the 24# Lucas injectors back in. Some of you know my history with getting this SR installed without leaking, so I'd rather not if I can avoid it.
In doing this I would hope to accomplish getting the fuel levels more stable and not as rich, but now I'm not sure if that's the problem. Where do I go from here?
Old Nov 9, 2003 | 07:42 PM
tkrussell's Avatar
tkrussell
You just said the magic words. The HC readings suddenly went up as you tuned leaner.
This is indicating that the mix is so lean that is is erratically igniting. Lean mixes are harder to ignite. So, unburned mix goes out the exhaust. Since the ignition is sporadic (if it always failed to ignite, the motor would not run), when it does ignite, the hot gasses burn the fuel in the headers---they glow red.
Solution is to get the mix back up richer in the RPM bands that the HC was excessive- idle. off idle,etc. If I understand the ECM program correctly, the mix should be 14.7:1 stoichiometric at closed loop idle and part throttle. The short and long term trim will compensate using O2 sensor feedback unless the injector size/pulse width, etc are too far off.
You dont mention it specifically, but check for lean at WOT also. If too lean at WOT, the pistons can cook in a hurry. Here, a tad rich is better 13:1 or so. Make sure your programming does not inadvertently lean out the WOT mix.
Old Nov 9, 2003 | 09:55 PM
mistaben's Avatar
mistaben
So did it work to make it pass emissions? I think when i finish my rebuild i may need to learn every trick in the book to make it pass. or if you want you can just send me an IM on what you did too. I am interested in how the story finishes.
Old Nov 10, 2003 | 08:31 AM
reallycoolcorvette's Avatar
reallycoolcorvette
your injectors are too big plus that 219 cam needs 8 to 10* of timing.
Old Nov 10, 2003 | 09:43 AM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
CFI,
I guess I should have chosen my words more carefully. I wasn't trying to be that semantical but you are right, I was trying to make the point that running lean could "definitely" cause the headers to glow red, I didn't mean to insinuate that was the EXACT and only problem.
Also, I was wrong saying that the cats, etc, could cause it to run lean, I meant what you said... that the ending result from those items could have the headers glow... I didn't literally mean that the cats were causing the lean condition...
Thanks for pointing that out, I guess I should have clarified my statement more carefully. I will make sure in the future.... I was trying to type out my thoughts that I didn't make myself crystal clear.
Mark
To Headers glowing red
