Criuse Control - Troubleshooting
Old Nov 9, 2003 | 10:09 AM
cyberblast's Avatar
cyberblast
Default Criuse Control - Troubleshooting
I bought my Vette a year ago, the cruise control was never working. Now i'd like to fix it.
Whats imporatant to check to locate the problem?
Old Nov 9, 2003 | 10:22 AM
tworottiedogs's Avatar
tworottiedogs
Default Re: Criuse Control - Troubleshooting (cyberblast)
I am no help but will be watching for any tips. Mine has never worked either.
Old Nov 9, 2003 | 10:48 AM
jfb's Avatar
jfb
First check the 3A cruise control fuse, LCD fuse, and the CLUSTER fuse. Check the vacuum hoses for leaks, splits, seated on nipples, etc. Many times the brake switch is out of adjustment, this switch is open circuit with the brake pedal depressed and on my 87 vette, the switch has a dark blue and a light blue (manual xmsn), grey/blk (auto xmsn) wires. Past these easy checks, you need the diagnosis table from the GM electrical diagnosis service manual, get one, its cheaper than 1/2 hour at the dealer!
Also, from now on it would be very helpful to state what year vette you are asking help for.
[Modified by jfb, 9:49 AM 11/9/2003]
Old Nov 9, 2003 | 11:01 AM
rick lambert's Avatar
rick lambert
Default Re: Criuse Control - Troubleshooting (jfb)
Gordon Killebrews 1984-1989 Digital Cluster book 29.95 is fantastic-it covers about everthing from diagrams to most common problems to testing to fixing.
Just type in Gordon Killebrew on your search .
I'm very pleased.
Old Nov 9, 2003 | 11:15 AM
cyberblast's Avatar
cyberblast
Thanks for your tips, i will check them out.
What i can say right now,
i've got also a '87 vette.
There is no LCD fuse in my box!
but if i want to put in a fuse, it come out again immediately.
What is the LCD fuse for?
Old Nov 9, 2003 | 11:21 AM
Blown Vette's Avatar
Blown Vette
You have a LCD fuse. The fuse is the 5A above the LCD. The one you are looking at is a blank.
Old Nov 10, 2003 | 02:55 AM
86PACER's Avatar
86PACER
Default Re: Criuse Control - Troubleshooting (Blown Vette)
:iagree:
To Criuse Control - Troubleshooting
