Heat shields (exhaust)
Old Nov 10, 2003 | 07:49 AM
Strick's Avatar
Strick
Default Heat shields (exhaust)
The OEM exhaust on the LT1 has heat shielding on the driver's side exhaust pipe coming out of the cat and extending back past the tranny. The catback systems I've seen so far, don't have that shielding. I wonder why? :confused: Some engineer/designer went to a lot of trouble to design it, you think there was a problem that required a shield?
Old Nov 10, 2003 | 08:34 AM
honas's Avatar
honas
Default Re: Heat shields (Strick)
If you replace the stock system you WILL notice the interior gets hotter without the shields. Probably too expensive and not enough room if you go with a bigger pipe.
