Another Tranny Gone!!!
Old Nov 10, 2003 | 10:00 AM
mn_vette's Avatar
mn_vette
Default Another Tranny Gone!!!
Well, I blew the tranny again, 5th time since late June. The first 4 were my 4L60 rebuilt. But this was a built 700R4 that they gave me out of frustration. I think it was missing the high rev kit and a shift kit, but it held up alot better than the others none the less.
The last time I talked to my mechanic he said that it's probably the gear ratio that's causing the problem. How ligit is that reason? I'm running a torquy 396 ci LT1 with a 2.59 rear end and a 1500 stall converter. Are there any other good reasons why I can't keep one in there.
I'm gonna give my mechanic a call today and see if he'll replace this one since it's only been less than 2 months since it's been put it.
[Modified by mn_vette, 3:57 PM 11/10/2003]
Old Nov 10, 2003 | 10:08 AM
MrNuke's Avatar
MrNuke
Default Re: Another Tranny Gone!!! (mn_vette)
Not to be a pill, but maybe, Just MAYBE it's time to find a BETTER mechanic / tranny shop? :eek:
Old Nov 10, 2003 | 10:11 AM
mn_vette's Avatar
mn_vette
Default Re: Another Tranny Gone!!! (MrNuke)
Actually, option #2 is to rebuild it my self. The guy is an awesome engine builder, but now that that's done the rest of the work I can do myself. But I'm still wondering if that's a ligit reason. Too little gear and too much torque would seem to be very hard on a tranny, but I'm not sure how hard. Oh yeah, I was running a 1500 stall torque converter.
[Modified by mn_vette, 3:13 PM 11/10/2003]
Old Nov 10, 2003 | 10:37 AM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
If it is under warranty let him have another try at it. Otherwise, find a new transmission guy......... :yesnod:
Old Nov 10, 2003 | 10:51 AM
scorp508's Avatar
scorp508
A good engine building is not necessarily a good transmission builder.
With that said, yes, a 2.59 is going to put more stress on the transmission and drivetrain up to the differential as it is harder to turn. In the same breath your torque convertor should absorb a lot of the shock. What kind of TC are you running?
Old Nov 10, 2003 | 10:57 AM
mn_vette's Avatar
mn_vette
Default Re: Another Tranny Gone!!! (scorp508)
He doesn't do the tranny work he sends it out to some other guy. But I'm running a 1500 stall torque converter.
Old Nov 10, 2003 | 10:58 AM
scorp508's Avatar
scorp508
The combo of 1500 and 2.59 could definitely be helping the breakage issue.
Old Nov 10, 2003 | 10:59 AM
mn_vette's Avatar
mn_vette
Default Re: (scorp508)
Do you think a 2500 and a 3.07 would significantly help??
Old Nov 10, 2003 | 12:59 PM
CFI-EFI's Avatar
CFI-EFI
Scorp,
I have to disagree. With that converter and gear, the rpms and resulting torque are held to a minimum, initially. A higher stall and lower gears are going to allow the engine to rev to a higher output, sooner. His set up screams for a converter and gears, but they won't be any easier on the trans. Without knowing any more of the details, it appears as though the trans builder is falling down on the job. Good luck, and...
RACE ON!!!
Old Nov 10, 2003 | 01:02 PM
scorp508's Avatar
scorp508
Default Re: (CFI-EFI)
I have to disagree.
Thats fine, but like you said his stuff screams for convertor/gears. That only means the points before that are going to be stressing the drivetrain to get there.
Old Nov 10, 2003 | 01:18 PM
CFI-EFI's Avatar
CFI-EFI
We seem to agree that his performance will benefit from a converter and gears. I don't understand what you're saying, here.
RACE ON!!!
Old Nov 10, 2003 | 01:19 PM
mn_vette's Avatar
mn_vette
I have to disagree.
Well, in either case I called my mechanic and he said that he wouldn't rebuild it unless I changed the gears. So I guess I'm going to rebuild it myself or I'm off searching for a new rear end.......
anybody know of someone selling a dana 44??? :confused:
Old Nov 10, 2003 | 01:27 PM
FD2BLK's Avatar
FD2BLK
You need to install a temp gauge on the trany the next time you have one installed. I am willing to bet your gears have very little to do with the problem and excessive temperature is the major cause. I would also get a pressure gauge and see what the pressures are set at for all gears before I ran the next transmission. Most overdrive transmissions fail due to heat or an improper TV setting. Using a pressure gauge to set up your TV settings and a temp gauge to monitor the trany to make sure it is properly cooling will prevent #6 from taking the same course as the other 5.
Old Nov 10, 2003 | 01:37 PM
scorp508's Avatar
scorp508
Ok well I'll try saying it slightly differently. :)
Something has to give and everything has a breaking point. If I dumped my clutch at 5000 with the tranny in 4th gear I'd probably expect something to fly out from under my car. :D
Old Nov 10, 2003 | 01:43 PM
mn_vette's Avatar
mn_vette
Default Re: Another Tranny Gone!!! (84LT1)
I installed a big tranny cooler and it was in the 40's outside. And I wasn't doing anything bad when it finally went out. Do you think there was added wear from being too hot, but not enough to kill it until now? That was the problem on the first two tranny's when the torque converter wasn't locking up, it would take out 3rd and OD. Now there's a lockup set to go whenever it's in 3rd. Perhaps that's why second is now out. Whats the proper temp range for a tranny?
Old Nov 10, 2003 | 01:50 PM
CFI-EFI's Avatar
CFI-EFI
Agreed on the breaking point. And the higher the torque the item is exposed to, the quicker the "breaking point" is reached. Dumping the clutch at 5000 rpms, is more like what will happen with a higher stall converter. With the trans in 4th gear, the parts that come flying out will be from the input shaft, forward. because there won't be enough torque miltiplication to hurt anything further back. Good luck, and...
RACE ON!!!
Old Nov 10, 2003 | 02:04 PM
mn_vette's Avatar
mn_vette
I think you hit it right on. The 2.59 rear end is big enough that it's like launching a 4.11 in second gear. And if the rear end is strong enough what's the next thing to go?
[Modified by mn_vette, 7:04 PM 11/10/2003]
To Another Tranny Gone!!!
Old Nov 10, 2003 | 02:27 PM
Vic'89's Avatar
Vic'89
Default Re: (mn_vette)
What actually broke in the Tranny ? 3/4 clutch pack or some "hard" part ?
Vic
Old Nov 10, 2003 | 02:30 PM
mn_vette's Avatar
mn_vette
Default Re: (Vic'89)
Vic
Not sure, but I think it's a clutch pack that brings in second gear. If I am going down the highway I can manually back the shifter into second and it won't ingage unless I push the pedal way down then it'll engage at a very high rpm but will be slipping alot. doing half the speed it would normally at that rpm.
Old Nov 10, 2003 | 06:50 PM
Beth396's Avatar
Beth396
Brian,
Definitely consider what Paul stated (84LT1).
I took out my 3/4 clutch pack the first fun filled weekend after I got the 396 and new tranny setup. It turned out to be both problems but mostly temp. My new exhaust system hugging the tranny pan, more heat with more displacement..
That tranny cooler may not be effective. Put a temp sensor in the tranny pan so you'll know next time and not drive it until you figure out why the transmission is failing.
A very large all aluminum radiator may be in your future...don't fight it. If you need a procedure to follow for pressure testing/TV cable adjustment, I have a word file I can send you.
Beth
