Need Help.....Please
Old Nov 10, 2003 | 06:06 PM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Default Need Help.....Please
I have a friend who owns a 94 Corvette engine code "P". His water pump went out (car was not driven after finding out, and still had coolant). Water pump was replaced, now car is overheating. He's had two different "Techs" bleed system, car still overheats. Tech also replaced a relay to the fans. With relay unpluged car does not overheat, with relay plugged in and fans working car overheats!..any Ideas will be greatly appreciated. Also what is the proper bleeding technique of the coolant system, Thanks!
[Modified by 3Vettes@Home, 7:00 PM 11/10/2003]
Old Nov 10, 2003 | 08:16 PM
iceman_t1's Avatar
iceman_t1
Default Re: Need Help.....Please (3Vettes@Home)
Did you check the radiator cap to make sure it has the correct spring? If the cap spring is too tight, it might not let the system work properly. I got a 15lb cap from GM and it fixed my slight problem. Also check the radiator hoses a couple hours after the car has been run. If the hoses are compressed, that could also be a sign that the cap is not the right one. Hope that helps.
Old Nov 10, 2003 | 08:22 PM
3Vettes@Home
Cruise-In V Veteran
Default Re: Need Help.....Please (iceman_t1)
Thanks! I'll have him check the cap :cheers:
Old Nov 10, 2003 | 10:29 PM
autotech's Avatar
autotech
The relay thing makes no sense to me. How could that be unless its just effecting the temp. readout? Anyway, I am not familiar with the year model but some have an air bleeder, usually near the thermostat, to get the air out. I doubt you have that. Some later models, any make, after about 1990 had problems when refilling coolant systems will get an air bubble in the system making it difficult th fully refill the coolant system. I found a tool thru Snap-On that pulls a vacuum on the coolant system when empty. It does 2 things, lets you know if you have any leaks and then draws the fluid into the system eliminating any posibility of air bubbles. I've been using it for years and it works great...Good Luck... :thumbs:
Old Nov 10, 2003 | 10:35 PM
autotech's Avatar
autotech
One last thing - Since the tool is a little expensive, you might take the vehicle a radiator shop as they should have the tool and could do it for you. :thumbs:
Old Nov 11, 2003 | 05:57 PM
CFI-EFI's Avatar
CFI-EFI
To me, there is only one possible explaination. Either the new relay is the wrong part, or it got wired incorrectly. The d.c. fan motor is wired with reverse polarity and turning backwards. That's the weirdest deal I've heard of in a long time, but it's the only explaination, given the facts. Good luck, and...
RACE ON!!!
Old Nov 11, 2003 | 06:01 PM
RichS's Avatar
RichS
Default Re: Need Help.....Please (CFI-EFI)
Did they put the drive coupling back on? A few times people here forgot to remove it from the old pump.
Old Nov 11, 2003 | 06:07 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Need Help.....Please (RichS)
If there were any problem with the water pump installation, it would overheat whether the relay was plugged in or not.
RACE ON!!!
Old Nov 11, 2003 | 06:55 PM
3Vettes@Home
Cruise-In V Veteran
Thanks for the help guys, I'll pass along this information :cheers:
To Need Help.....Please
