Fast Burn Heads
Old Nov 10, 2003 | 09:00 PM
87BLKVETTE's Avatar
87BLKVETTE
Default Fast Burn Heads
I am curious to know if anyone has installed GMPP's fast burn heads on a L-98. The way that they are written up, it seems like they are a "no additional porting needed", use right out of the box godsend. I am entertaining doing some performance upgrades come springtime, and want to keep my options open.
Thanks :cool:
Old Nov 10, 2003 | 10:29 PM
Mr6spd's Avatar
Mr6spd
Default Re: Fast Burn Heads (87BLKVETTE)
The Fast Burn heads are a great design, with arguably the most efficient combustion chamber design out there for the traditional small block. The only place GM fell short with these is the valves and crude valve job. Buy a set of 2.055 Intake and 1.60 exhaust valves, and have a great 3 or more angle valve job done, and the fast-burn heads will rock.
Old Nov 10, 2003 | 10:58 PM
srfrench67's Avatar
srfrench67
2nd Gear
I am currently installing a ZZ4 short block with Fast Burn heads and the LT1 hot cam into a 90 Vette for a customer, the FB heads have an extreamly high intake runner which is designed for a Vortec style intake, to make the TPI unit work you will need to use intake gasket part# 12497760. When the TPI is placed on the FB heads, 1/4 inch of the top of the intake runners are exposed on the heads, the gaskets I listed are approx. 3/16 thick and will make the TPI work.
Old Nov 11, 2003 | 08:00 PM
JackDidley's Avatar
JackDidley
Default Re: Fast Burn Heads (srfrench67)
Scoggin& Dickey sells a base intake just for fastburns. Thinking about getting one with a set of E Tech 200 fastburns myself. :chevy
Old Nov 11, 2003 | 09:24 PM
Mr6spd's Avatar
Mr6spd
Default Re: Fast Burn Heads (Spankyellow)
Beware of the Etechs. Reportedly, Scoggin Dickey has tested these themselves, with their TPI base. The results were that they did not put out anywhere near the power that the GM Fast Burns did. This despite advertising higher out-of-box flow numbers. I'm sure it has everything to do with combustion chamber design, mixture velocity and swirl, etc.
Old Nov 11, 2003 | 10:53 PM
tkrussell's Avatar
tkrussell
How does the Fast Burn head compare to the AFR 195 head?
Both have small combustion chambers designed for use with a flat piston.
Or does the Fast Burn head more closely compare to the AFR 210 heads?
Old Nov 12, 2003 | 08:32 AM
JackDidley's Avatar
JackDidley
Default Re: Fast Burn Heads (Mr6spd)
Tell me more. Get this from S&D, magazine , wheere? I dont doubt you at all I just want the best info I can get before spending cash. :chevy
Old Nov 12, 2003 | 09:59 PM
Mr6spd's Avatar
Mr6spd
Do a search on http://www.thirdgen.org The post was from someone who called Scoggin Dickey and talked with one of the guys who was intimately involved with the Vortec TPI manifold development and testing.
To Fast Burn Heads
