Porting stock Intake?
Old Nov 11, 2003 | 01:55 PM
TheStef's Avatar
TheStef
Default Porting stock Intake?
I know this has been posted before, but I'm honnestly curious.
Does any one have a detailed web site explainning how to port the stock TPI Intake? what tools to use, what parts of the plennum and/or runners to port.
I'm currently doing a search on the forrum, but a web site with lots of details would be very cool. :)
Thanks guys
[Modified by TheStef, 12:55 PM 11/11/2003]
Old Nov 11, 2003 | 02:47 PM
Greenvette's Avatar
Greenvette
Default Re: Porting stock Intake? (TheStef)
http://sethirdgen.org/TPIbase.htm.]h...sethirdgen.org
. then go to techcentral at the top of the page then, go to engine fuel.</A> They show how to port the intake base.http://www.3gc.net. then go to articles and then engine and then TPI mods.."
[Modified by Greenvette, 12:01 PM 11/11/2003]
[Modified by Greenvette, 12:02 PM 11/11/2003]
[Modified by Greenvette, 5:42 AM 11/12/2003]
[Modified by Greenvette, 5:43 AM 11/12/2003]
Old Nov 11, 2003 | 03:29 PM
TA's Avatar
TA
Default Re: Porting stock Intake? (Greenvette)
links no workee :cry
Old Nov 11, 2003 | 04:08 PM
TheStef's Avatar
TheStef
Default Re: Porting stock Intake? (TA)
I've done a lot of reading. If I'd really wanted to port my stock TPI Intake I would have to start from the bottom going up for any real HP increase. First porting the Intake base manifold then the runners, then the plenum.... or simply installing bigger runners or Siamese runners and porting them as well.
Does any one know aprox how much HP gain is expected from a ported Intake base manifold, bigger runners and ported plenum? any dyno sheets?
Old Nov 11, 2003 | 05:14 PM
TA's Avatar
TA
I don't have any dyno data specifically from these mods alone, but my guess would be somewhere in the neighborhood of 15-20hp. With the addition of 24 lb injectors, an AFPR, 1.6 RRs, Accel base, AS&M runners and a ported plenum I gained 40 rwhp and 71 rwtq.
Old Nov 11, 2003 | 10:00 PM
montie98's Avatar
montie98
I dont know if you have a shop or you are an amature. But if you are somewhat of an amature like me send this work out! I did mine myself and after I was done with all the bits and tools and crap and time it took it would probally cost know more to just send out the intake and have it done nice and profesional
Old Nov 12, 2003 | 12:11 AM
boxerlover79's Avatar
boxerlover79
Default Re: Porting stock Intake? (montie98)
any idea how much the average is on getting the intake ported professionally?
Old Nov 12, 2003 | 12:28 AM
1996man's Avatar
1996man
Default Re: Porting stock Intake? (boxerlover79)
i dont know about TPI intakes but i can get a LPE professionally ported and polished LT4 intake manifold if i send mine in for 300 bucks
Old Nov 12, 2003 | 01:24 AM
BAM92's Avatar
BAM92
Default Re: Porting stock Intake? (1996man)
Mine was done by LPE for 300. Just reread your post. Extrude hone seems to do a very good job on tpi's.
[Modified by BAM92, 1:26 AM 11/12/2003]
Old Nov 12, 2003 | 02:03 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I ported my plenum, matched the throttle body to the plemum, added an air foil and port matched the plenum to the tubes. I got a good seat of the pants improvement! Probably around 10-12 hp at the upper end! I did the porting when I had to replace my EGR valve. If you ever get the chance to look inside the plenum you wil see that it has MAJOR room for improvement!
I purchased a set of simese runners and was going to port the base but sold the car before I was able to do the project. It didn't look to be very difficult to match the results of one of the high $$$ units that can be purchased from a number of places.
IMHO you would only see benifit at the mid RPM to upper end of the RPM band.
If you did some head and cam work the base, runner and plenum work would really come to light.
A stock motor will not have any major HP gains. Don't get me wrong. Any work in the intake area will show benifits but dont expect a lot from just the port job.
I still have the simese runners!
Bill C
Old Nov 12, 2003 | 03:26 AM
ToniH's Avatar
ToniH
> links no workee
Take the dots out from the end of the links and they work fine.
ToniH
Old Nov 12, 2003 | 12:09 PM
boxerlover79
Default Re: Porting stock Intake? (Bill Curlee)
BILL how much you want for the siamese runners?
To Porting stock Intake?
