Check Gauges
Old Nov 12, 2003 | 10:28 PM
1990CORVETTE's Avatar
1990CORVETTE
Default Check Gauges
OK, Here is one for all you guru's out there.
Every since I bought my 90,,,, the "check gauges" light right next to my speedometer........ Does anyone have a clue why? :cheers:
Old Nov 12, 2003 | 10:38 PM
jefft84's Avatar
jefft84
Default Re: Check Gauges (1990CORVETTE)
It comes on when one of the monitored systems is out of normal parameter.
low or high charge voltage,high coolant temp,low fuel are the primary triggers. However poor grounds can also be mistaken for a problem and the light comes on.
Old Nov 12, 2003 | 11:00 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Yeah if your coolant temp, oil temp goes way high, it will come on to warn you to, well check your gauges
also when you hit below reserve on your gas tank it will come on.
Old Nov 14, 2003 | 09:30 PM
dlmeyers's Avatar
dlmeyers
Default Re: Check Gauges (Mr Mojo)
For the Model Year 90-
Page 84- Owners Manual-
"If the CHECK GAUGES light comes on, look at the oil pressure, oil temperature, and coolant temperature gages to see which gage or gages are in the cross-hatched area. Then follow the instructions given in this manual for each page. "
For the MY 90, electrical output is not monitored by this circuit.
The fuel low signal for the 90 is monitored and displayed as "RESERVE" when fuel level reaches the last two bars. Not sure if it is supposed to flash. Maybe the fuel was sloshing around.
The CHECK GAUGES light will do a self test on start up, then go out. If the key is left on, engine off, the light should remain on due to no oil pressure.
Cars are a hoot.
dlmeyers 90 coupe zf6 3 speed shocks
To Check Gauges
