C4 - code 42 (Electronic Spark Timing Circuit (EST))
Old Nov 14, 2003 | 08:19 AM
tmcorvette's Avatar
tmcorvette
Default C4 - code 42 (Electronic Spark Timing Circuit (EST))
I've got code 42 (EST) in my '88 'Vette. Is anybody here who knows what should I check? Please help me...
Old Nov 14, 2003 | 11:53 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: C4 - code 42 (tmcorvette)
thats the connector you undo for base timing... located on main harness, usually by wiper motor... my 87 has tan wire with black stripe...
could also be stuffed in the wire bundle...
Old Nov 14, 2003 | 06:02 PM
nobodyunknown's Avatar
nobodyunknown
42 Electronic Spark Timing (EST) circuit - open or shorted to ground during engine run
OR Direct Ignition System (DIS) fault - bypass circuit open or shorted ground during engine run
OR Fuel Cutoff Relay Circuit - open or shorted to ground
Old Nov 14, 2003 | 07:18 PM
ittlfly's Avatar
ittlfly
Default Re: C4 - code 42 (nobodyunknown)
Have you had your knock sensor(s) out recently? They need to be torqued to 14lbs. To tight and they can cause a code to trigger. Otherwise, the car is 15 yrs old and they may need replacment. They are fairly cheap. :thumbs:
Old Nov 15, 2003 | 12:42 PM
tmcorvette's Avatar
tmcorvette
Default Re: C4 - code 42 (ittlfly)
Thanks for your answer, I'll check these things... and waht about ignition modul, maybe do I have to change it? :smash:
Old Nov 15, 2003 | 12:53 PM
Damien89's Avatar
Damien89
I Have the same problem but can't solve it. I already changed the ignition module and there was no change. Does the problem always come out when you start the car or it sometimes doesn't?
Old Nov 18, 2003 | 08:52 AM
tmcorvette's Avatar
tmcorvette
Default Re: C4 - code 42 (Damien89)
Sometimes when the engine is not cold there isn't any code, but if the car is not started for one day the code 42 appear. Did you check the knock sensor?
Old Nov 18, 2003 | 10:39 AM
87SAM's Avatar
87SAM
Here's a little blurb from my 87 manual....
Circuit Description:
When the system is running on the Ignition Module, that is, no voltage on the bypass line, the Ignition Module grounds the EST signal. The ECM expects to see no voltage on the EST Line during this condition. If it sees a voltage, it sets Code 42 and will not go into the EST mode.
When the rpm for EST is reached (about 400 rpm), and bypass voltage applied, the EST should no longer be grounded in the Ignition Module so the EST voltage should be varying.
If the bypass line is open or grounded, the Ignition Module will not switch to EST mode, so the EST voltage will be low and Code 42 will be set.
If the EST line is grounded, the Ignition Module will switch to EST, but because the line is grounded there will be no EST signal. A Code 42 will be set.
Old Nov 18, 2003 | 02:05 PM
Damien89's Avatar
Damien89
I did check it a little bit but not to be certain if its it or not because i was told that would cause code 43 not 42
Old Nov 18, 2003 | 03:55 PM
JAKE's Avatar
JAKE
When I first bought my 86 several years ago, I had the same problem and went throught all sorts of checks to determine the cause.
Finally, I borrowed an ECM from a buddy's 86, plugged it in , cleared the stored code and all was well.
My problem was in the ECM, so I bought a remanufactured one from O'Reilly's Auto Parts ($100). That solved the problem and I haven't had any trouble since.
Hope thisn helps.
Jake
Old Mar 6, 2020 | 05:11 PM
Jer Frenchik's Avatar
Jer Frenchik
5th Gear
Default How in the hell is that help with any kind of problem about the electronic spark timi
yes but how does that help with anything
Old Mar 6, 2020 | 10:35 PM
aklim's Avatar
aklim
The OP probably has fixed it or tossed it by now.
Old Mar 7, 2020 | 06:14 PM
Jer Frenchik
5th Gear
Default I would ask a question most places mechanics that are qualified don't even do the OB
Originally Posted by ihatebarkingdogs
Be sure the connector is plugged together. The most common cause is that the connector is not plugged in. OR the code was set while setting the timing, and the code was not cleared. Try clearing it, and see if it stays away. If it does, the "problem" is fixed.
You found a 17 year old thread to jump into. If you have current questions, or need help with your car, it would probably serve you best to start a new thread rather than append a 17 year old one.
I just had more of a question of a qualified mechanic working and analyzing the OBD1 computer to fix it most the most qualified mechanic shops turn me away when they OBD1 reading
To C4 - code 42 (Electronic Spark Timing Circuit (EST))
