Need help by tomorrow.... Please Timing issue...
Old Nov 15, 2003 | 12:50 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
Default Need help by tomorrow.... Please Timing issue...
Since I'm sending my computer out AGAIN to get the gears redone, should I have any timing changes done? I need some help from some of the experts here. The engine is out of my '95 vert. Here are some stats.
58 mm Throttle body
355 block (bored .030", stock compression on pistons)
30 lb injectors
.586 lift exhaust
.248 @.050" duration
1.6 rollers
heads ported and polished
160 thermostat
2800 converter
3.54 gears
shorty headers
k&N filter w/ opened front case
I left the stock timing in the ECM but was thinking about having it advanced. Any suggestions?
Just out of curiousity, anyone have probably HP ideas? I was going to have it dynoed today until I realized that I had to send the computer back again since the gear change in the ECM didn't work.
Thanks,
Mark
Old Nov 15, 2003 | 03:21 PM
96GS#007's Avatar
96GS#007
Default Re: Need help by tomorrow.... Please Timing issue... (C4 Newbie)
Without the ability to datalog during driving to see what's happening, advancing the timing may result in spark knock. If that occurs the PCM will retard timing and cost you hp.
I'd leave well enough alone. If you feel you have to add something, have them add 3-5* below 3000 rpm in the 75kPa regions and up. You should pick up just a little low end torque. Just remember, depending on what they've already done, adding any more could end up being too much.
By doing this blind (no datalogging), add timing at your own risk!
[Modified by 96GS#007, 2:22 PM 11/15/2003]
Old Nov 15, 2003 | 07:49 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
Default Re: Need help by tomorrow.... Please Timing issue... (96GS#007)
96GS,
Thanks for your input. Though each engine will require something different, I didn't know if there was some "rule of thumb" that LT1's run better with advanced timing.
Rather than guess, I'll just leave it alone. If no one knows for sure, don't want to do anything that will be detrimental in way of performance/durability.
Thanks,
Mark
To Need help by tomorrow.... Please Timing issue...
