TIMING RETARD USING 100 SHOT
Old Nov 16, 2003 | 11:01 AM
red-y's Avatar
red-y
Default TIMING RETARD USING 100 SHOT anyone??
DO YOU USE A RETARD SYSTEM? WHAT KIND?
[Modified by red-y, 5:56 PM 11/18/2003]
Old Nov 16, 2003 | 09:00 PM
Dan Parker '96's Avatar
Dan Parker '96
Default Re: TIMING RETARD USING 100 SHOT (red-y)
I don't use a "system". Just pulled out 3 degrees of timing on the top end with LT1 Edit. This for a 100hp TNT setup.
The dyno numbers didn't seem to care about the 36degree max timing (stock timing would show 39-40 degrees) when off the nitrous. The timing retard is just a little extra insurance.
Old Nov 23, 2003 | 11:53 AM
MasterDave's Avatar
MasterDave
Moderator
Default Re: TIMING RETARD USING 100 SHOT anyone?? (red-y)
For a 100 wet shot, just run it. Don't need to change anything. :thumbs:
Old Nov 25, 2003 | 07:13 PM
red-y's Avatar
red-y
Default Re: TIMING RETARD USING 100 SHOT anyone?? (MasterDave)
MasterDave - Post your modifications - thanks
Old Nov 26, 2003 | 09:58 AM
MasterDave's Avatar
MasterDave
Moderator
Here....
Old Nov 27, 2003 | 08:22 AM
red-y's Avatar
red-y
Beautiful car :seeya
Old Nov 28, 2003 | 02:32 AM
fiberglasscoffin's Avatar
fiberglasscoffin
im running a 150shot not pulling any
Old Nov 29, 2003 | 01:23 PM
dizwiz24's Avatar
dizwiz24
Default Re: TIMING RETARD USING 100 SHOT anyone?? (fiberglasscoffin)
On my 93, ed wright fast chip, hotcam kit, TPIS LT headers, no cats, NX 100 wet shot, no timing retard is needed.
I should also add that the NX recommended fuel side jet caused it to run rich on nitrous. A wide band dyno run confirmed that. I went one size smaller on the fuel jet, got more HP. No problems with detonation (no knock retard on scan tool).
Good luck.
Keep in mind if you do run timing retard, MSD's digital 6 plus is garbage. I went through 3 of them.
Old Dec 1, 2003 | 08:20 PM
red-y's Avatar
red-y
Default Re: TIMING RETARD USING 100 SHOT anyone?? (dizwiz24)
Dizwiz - Finally someone to confirm my problems with MSD and answer the retard question. Thanks for the post. Looks like my nick name of NoNos will change to Mr. Nos. I took off the MSD crap and now trying to decide to run without retard. I did add a new high powered Accel Coil.
Sounds like I am good to go.
Thanks again for your input. :seeya
[Modified by red-y, 7:22 PM 12/1/2003]
To TIMING RETARD USING 100 SHOT
