loose steering column
Old Nov 17, 2003 | 04:48 AM
aussie 84vette's Avatar
aussie 84vette
Default loose steering column
hi guys, since ive had my 84 the steering column has been a little loose. i was told it might be the 3 0r 4 torque bolts could be loose. so after stuffin around pullin it all appart i found that they were tight. now what else could it be? bearings? or the pivot where the steering can be adjusted up and down? and could this be the main reason im having a rough ride? please help :confused:
Old Nov 17, 2003 | 09:03 AM
Midwest Vette's Avatar
Midwest Vette
Default Re: loose steering column (aussie 84vette)
I had the same problem with my 93, It was the pivot piece. They are pot metal & the pivot pins get lose. It was'nt too bad of a job, I pulled the whole column and worked on it on the bench.
Good luck Ron :thumbs:
Old Nov 17, 2003 | 11:34 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
can't find it now. but there was a great tech tip on 84-87 steering columb work... if you email me, i'll send you the tech tip ...
Old Nov 17, 2003 | 09:45 PM
Kens86's Avatar
Kens86
I believe these are the tech tips that Vinnie is refering to. I used them and found them invaluable.
http://www.chevyasylum.com/column/tiltcol.html http://www.gnttype.org/techarea/susp..._steering.html [IMG][/IMG] :yesnod:
Old Nov 18, 2003 | 08:04 AM
aussie 84vette
yeah i think it could be the pivot pins cause it feels like its at the top end of the column. those links are very handy thanks for the help guys.. :cheers:
To loose steering column
