Mini ram guys
Old Nov 17, 2003 | 12:44 PM
LayZ's Avatar
LayZ
Default Mini ram guys
What setup's are you running? i finally got mine and it's going to the powder coater this week. But what kind of Throttle body are you running? I still have to get one but this is my thinking. I have 24lb injectors, the mini ram, a z409 cam from TPIS, and i was going to get the 52 throtle body. Stock heads for now but hopefully with the next few months maybe some AFR's. Just wondering what the rest of you guys run.
Old Nov 17, 2003 | 02:18 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: Mini ram guys (LayZ)
-350CI
-52mm TB
-ZZ9
-1.6/1.5 rockers
-Long tube Hooker headers
-CNC Ported L98 heads
Best time in Signature
Old Nov 17, 2003 | 02:31 PM
LD85's Avatar
LD85
Default Re: Mini ram guys (-=Jeff=-)
-406CI
-58mm TB - BBK
-currently 225/233,, coming soon 233/239 Hyd Roller
-Long tube Hooker headers 2151-1
-AFR 210 RR heads being built/due 12/7/03
-30# SVO
Old Nov 17, 2003 | 02:33 PM
LayZ's Avatar
LayZ
WOW that's with 30lbs injectors, hmm maybe i should rethink that 24lbs. That's awsome 12.55 in the quater nice.
Old Nov 17, 2003 | 02:42 PM
-=Jeff=-'s Avatar
-=Jeff=-
Yeah, i forgot to add that it is 30# injectors, I did have 24# but I was planning on building my 400 SBC and got them for that. but due to other reasons I was unable to build the 400. So I kept the 30# on there. The 30s work well but I had to do a bit of tuning to get the fuel just right. I actually think there is more then a 12.55 in it, but I need to tune more at the higher RPMs and back down my timing at WOT
Old Nov 17, 2003 | 10:44 PM
tpi 421 vette's Avatar
tpi 421 vette
My numbers are in my sig. :cheers:
Old Nov 17, 2003 | 11:34 PM
VanSpeed's Avatar
VanSpeed
Highlights
350 CID
Mini Ram
TPIS hydraulic cam (I forget the specs, but its pretty big for a hydraulic)
TPIS stage I AFR heads
TPIS long tubes
58 mm BBK TB
Formato chip
Stock injectors
Stock bottom end
etc.
I haven't ever drag raced my car, I do run track days at PIR (Portland, OR)regularly. I don't know how much to relate to the 58mm TB, but the overall package works well together.
Brian
Old Nov 18, 2003 | 12:47 AM
hookedup's Avatar
hookedup
Default Re: Mini ram guys (VanSpeed)
420, MRII, Brodix T1s, 58mm, CC HR custom grind, chip by Jesse, Th350, 4.10......
To Mini ram guys
