C4 Winter projects
Old Nov 17, 2003 | 10:49 PM
chb88's Avatar
chb88
Default C4 Winter projects
The year has ended early. The car decided it was time to go into hibernation thanks to a blown clutch. Was going to replace the clutch with stock, and do the slave and master at the same time. Now if only those 6 exhaust manifold bolts will come out? Starting with a sock in PB Blaster. We'll see if that stuff lives up to the claims.
The other night while reading the forum someone had a post of what seemed to be all the things that happen to the C4 by milage. My 94 coupe is at 73600 and seems to be all stock. I was going to replace the water pump, Blistines, and rear wheel hubs (those bad boys have a good 1/8' top to bottom slop), which explains the grinding noise in the rear the end of last summer.
I have been looking into stiffing the frame to eliminate the Flexible Flyer with the top off experience and it seems everyone has a different idea for the fix. Does anyone have the definitive solution to the handling issue? I am considering the cross frame brace only because I want to keep the stock look and don't particularly like the idea of removing the roof and then installing the Roof Truss bar. Seems like to much work . Thoughts?
Also is there a spread sheet of things to do by milage to a 94? (MUST DO, SHOULD DO, WOULD BE NICE TO DO, ETC). Experience helps here way more than the owners manual.
Any help appreciated. :rolleyes:
