This is going to be the first time using PC program/cable on my 87. I'v heard the you (1) turn the ign to on, then, (2) insert the pins in the connector
or
(1) insert pins in connector, then, (1) turn ign to on position.
Just want to make sure that i have the procedure correct....
then, after communications link... its okay to start the car and log results.
