Quick question on "Rod Knock"
Old Nov 18, 2003 | 01:05 PM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Default Quick question on "Rod Knock"
...What causes it? :confused: I mean, I know what you can do to make it happen, but what in the engine actually knocks? Is it the same as piston slap?
No, I don't have any problems, I'm just wondering. :cheers:
Old Nov 18, 2003 | 01:14 PM
BLACKVETTE95's Avatar
BLACKVETTE95
Default Re: Quick question on "Rod Knock" (ShawnZR-1)
Rod knock is caused by spinning the rod bearings(allowing too much clearance).
I did this when I over-revved 3 times.
As you drive the car, you will hear knocking at around 2000-3000 rpm.
It is a non-pleasant and expensive noise.
Old Nov 18, 2003 | 01:15 PM
scorp508's Avatar
scorp508
A spun/failed rod bearing.
The rod instead of sliding around smoothly on a bed of oil between the rod and bearing/crank begins to slam against the crank directly and may also hit areas of the block if they are in close proximity.
It sounds like a very deep hollow knocking noise low in the engine that varies with RPM.
Old Nov 18, 2003 | 01:40 PM
ShawnZR-1's Avatar
ShawnZR-1
Default Re: Quick question on "Rod Knock" (scorp508)
Ahhh!!!! Thanks guys! That makes sense.
To Quick question on "Rod Knock"
