Headlight stalk control won't activate brights...
Old Nov 19, 2003 | 09:59 AM
Atchisbr's Avatar
Atchisbr
Default Headlight stalk control won't activate brights...
Last night I tried to turn on my brights, but the stalk that is used to activate them wouldn't click forward turn them on. The blinkers and cruise control still work, but the brights do not.
Has anyone heard of anything like this? A broken stalk? Something lodged in there?
Any ideas would be great.
Bryan
Old Nov 19, 2003 | 10:12 AM
bogus's Avatar
bogus
Default Re: Headlight stalk control won't activate brights... (Atchisbr)
sounds like the stalk has broken...
they are not the best build things, sad to say.
Old Nov 19, 2003 | 10:14 AM
QuikZilver's Avatar
QuikZilver
When I bought my Vette, I had the same problem. Check to see if your highbeams work with the steering wheel all the way up (not tilted down). If so, good chances the switch is just loose in the column. The dealership had to tighten mine up.
:cheers:
Old Nov 19, 2003 | 04:39 PM
Atchisbr's Avatar
Atchisbr
Default Re: Headlight stalk control won't activate brights... (Whitvette)
Thanks for the info. I will check mine tonight and see what happens.
Old Nov 20, 2003 | 02:07 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
If your stalk is broken,,, drop me a line, just finished replacing new one today... not a hard job, but make sure you have the right tools, (1)steering wheel puller and (2) lock cam compressor (best one from AutoZone for $9)..
Old Nov 20, 2003 | 06:13 AM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
Default Re: Headlight stalk control won't activate brights... (vinnies87)
Vinnie,
I haven't done one on a corvette but are they like most GM's where you have to tie a piece of mechanic wire to the connection to pull it through and then attach the mechanic wire to the new lead to pull it back through when installing the new stalk?
Thanks,
Mark
Old Nov 20, 2003 | 11:49 AM
vinnies87's Avatar
vinnies87
Default Re: Headlight stalk control won't activate brights... (C4 Newbie)
If it just the turn signal stalk, then it just requires 1. remove steering wheel, 2. remove lock cam, 3. remove screw holding stalk in the turn signal cam, 4. put in new turn signal stalk. If you have to replace the whole turn signal cam assy, thats a different story... all the same as above, + some more
To Headlight stalk control won't activate brights...
