White face gauges
Old Nov 19, 2003 | 08:04 PM
91z07's Avatar
91z07
Default White face gauges
Got some white face gauges off ebay. Looking for installation tips from someone who's done this on a 90+. Any help out there? :thumbs:
Old Nov 19, 2003 | 08:09 PM
bogus's Avatar
bogus
Default Re: White face gauges (91z07)
no, but pics when your done would be cool.
Old Nov 19, 2003 | 08:20 PM
91z07's Avatar
91z07
Default Re: White face gauges (bogus)
Well I would, but for me, figuring out how to do that would be another search topic in itself! :thumbs:
[Modified by 91z07, 7:21 PM 11/19/2003]
Old Nov 20, 2003 | 09:05 AM
eddieL98's Avatar
eddieL98
Doh! i was supose to post pics for someone else i totally forgot. I'll e-mail myself a reminder to post some tonight.
install tips:
do the install while the car is cold
take a picture of the gauge needles
if you have the manual just follow the instructions for removing the instrument cluster.
wear latex gloves while installing(keeps the faces clean)
before closing everything up check to see if all the guage needles work
also check to see where your door ajar light is compared to the one you bought and make sure they sent the right one.
hope this helps. will post pics tonight with the green and blue lights
Old Nov 21, 2003 | 07:24 PM
91z07's Avatar
91z07
Default Re: White face gauges (eddieL98)
Thanks!! Where'd you install the switches? :thumbs:
[Modified by 91z07, 6:27 PM 11/21/2003]
Old Nov 21, 2003 | 08:22 PM
eddieL98's Avatar
eddieL98
well the switch is next to the center consol. you can almost see it in the third pic.
Old Nov 21, 2003 | 11:46 PM
BAM92's Avatar
BAM92
Eddie could you email me pics. tikibam2@msn.com . I only got red x's from your post. I was curious what this looks like on a vette as I have them on both my trucks. Thanks.
Old Nov 22, 2003 | 07:38 PM
91z07's Avatar
91z07
I'm not getting you're pic's either. :confused: BTW, mainly what I'm concerned about is the warning in my Haynes manual (can't find my GM manual at the moment) that the instrument cluster "cannot be disassembled by the home mechanic." I guess I better look a little harder for my GM manual. :yesnod:
[Modified by 91z07, 6:46 PM 11/22/2003]
Old Nov 23, 2003 | 01:34 PM
aftermath's Avatar
aftermath
I put a set of these on my 90. dropping the colum it the best way to do it . remove the outer black trim. the cluster will the pull out. then you just take out the handful of screws that hold the lense in place and from the backside remove the screws that hold the inside trim plate to the face. the gauges then sit on the face positioned with a few holes that line up on the cluster , the needled feed into the holes in thewhite no need to pull em. the hook up power and test. and now reassemble and install.
*** note not good idea to try without dropping the colum, i did the first time and scratched my lense cover and cracked my LCD before it was over!!! :smash: also i dont know if new ones are like the but the ones i have dont match up exactly to factory markings on cluster***
Billy
To White face gauges
