After changing the spark plugs on my 1990 conv. the temp. gauge stopped working
I have looked around the intake mainfold & heads to check the connection to the sending unit but i just can't seem to locate it.
Does any one know where the temp sending unit is located?
More than likely you knocked the wire off of the temperature sending unit. Look between #6 & #8 header tubes (passenger side, last 2 tubes closest to the dash board) for the sending unit. Its a brass plug with an epoxy center that has a pin or spade male plug protruding form it. You'll probably find the wire and clip hanging right around the spark plug for #8 cyl (last one closest do dash board on pass side. Plug it back in, you'll probably be in good shape. :cheers:
