Replacing EGR Temp. Switch
Old Nov 21, 2003 | 08:39 AM
ROCKY85's Avatar
ROCKY85
Default Replacing EGR Temp. Switch
First time doing this how tricky is it ? and how long should it take?
Rocky
Old Nov 21, 2003 | 11:39 AM
Unriced's Avatar
Unriced
Default Re: Replacing EGR Temp. Switch (ROCKY85)
Should take a couple of hours the most.. Remove airbox and it's right there.
You shouldnt have to remove EGR valve... You might want to put a meter
across it to make sure it's bad. Cold it should read open and warm/hot
should be closed. Mine was stuck closed, tripping a code 32 until the
car warmed up. HTH
Old Nov 21, 2003 | 12:37 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If it's like my '88 the connector to that grn wire comming out of the switch is burried behind, below and to the left of the dist with a 2" pigtail comming out of the large harness that runs across the top of the bell housing.
When I had the base off with dist out I spliced in a section of grn wire to bring that connector up to the right of the dist for easy access.
Otherwise replacing the EGR temp. switch would have been a 5min job.
To Replacing EGR Temp. Switch
