Mufflers do not enhance engine output. True?
On my '95 with the stock exhaust I ran 13.0. On that car I removed the mufflers and only realized a gain of .08 in the 1/4 but my mph was reduced by 1.5 mph. So that indicates a power loss.
I out a Corsa catback system on and got the 1.5 mph back, so something is said about having mufflers, or at least the proper one.
To say that such and such "added" 10 horsepower, as many people do, is really an incorrect statement. You didn't add it, it was already there. On a particular engine, removing the mufflers might remove a restriction that allows the engine to achieve more of its potential. On another engine, removing the mufflers might take away a critical part of the system that the engine was tuned to operate with. In that case, you would lose horsepower and/or torque.
On my LT1 when I removed the mufflers, I felt like I lost some sub-3k rpm torque. Don't have any dyno numbers to prove it, but I could feel it. Maybe it was actually just a change in throttle response. I don't know, but something was different. Putting mufflers back on restored the low-end zip.
So obviously on my particular engine, the thing is designed to work with some backpressure. May be different for someone else's engine. The only way to really know for sure is to tune the thing on a dyno.
Sorry for rambling there.
Really it all comes down to the individual motor and what its power band is. L98 needs a little back pressure, LT1/4 also. A motor like the ZR1 which makes less down low torque and more high rpm power can benefit from no back pressure, but it will be at the expense of bottom end torque.
[Modified by Davidsvette85, 2:21 PM 11/23/2003]
[Modified by Davidsvette85, 2:22 PM 11/23/2003]
The game of horse power is majority based on unrestricting the flow of air and fuel. Restricting either results in less performance... Good headers are "tuned" to actually help "pull" exhaust from the motor. This is done because back pressure and restriction are not performance enhancers. :lurk:
[Modified by c4power, 9:23 AM 11/23/2003]
Go ahead and run your car with no exhaust and see what happens, you'll more than likely slow down.
Comparing a top fuel car to a street/strip car is not entirely apples to apples. When done properly, a tuned exhaust will help a car unless it is simply designed to run at insane RPMs.
