ECM Chip to change shift points
Old Nov 23, 2003 | 11:20 AM
JFMC5's Avatar
JFMC5
Default ECM Chip to change shift points
I have an 84 with an automatic. I read somewhere that you can replace the chip in the ECM to increase the shift points. Around town the trany shifts through the gears to quickly unless I am accelerating rapidly. From what I have read this is fairly normal. Does anyone have any knowledge of these chips, are they worth it, and where can you obtain them. I have adjusted the detent cable, it helped a little, but still not where I would like it.
Old Nov 23, 2003 | 11:46 AM
vader86's Avatar
vader86
Default Re: ECM Chip to change shift points (JFMC4)
No, putting a chip in an 84 wont do anything. The ECM controls very little of the transmissions functions. You have to change things internally in 84 to fix that.
In 94-96, yes since the ECM controls the transmission, not in 84.
Old Nov 23, 2003 | 11:51 AM
CFI-EFI's Avatar
CFI-EFI
Shift points are only ECM controlled in later cars using the 4L60E transmission. Adjusting the TV cable had a very small impact on the shift points in my '84. It did affect shift firmness. The only real way to change the shift point is to buy a govenor recalibration kit and start fooling with the weights and springs. Good luck, and...
RACE ON!!!
Old Nov 23, 2003 | 02:58 PM
tjwong's Avatar
tjwong
A chip in a 84 car doesn't control the transmission at all. It may control the lock up convertor (TCC) if it does anything. I know that in the 85 model year it does control the lock up point, so it may also in an 84. In the 85's the TCC would lock up at an annoying low speed causing the engine to lug once it shifted into 4th gear. Adding a shift kit and changing the lock up point greatly improves reliability and shifting.
Old Nov 23, 2003 | 07:38 PM
JFMC5's Avatar
JFMC5
Default Re: ECM Chip to change shift points (tjwong)
You hit the nail on the head. The chip controls when the ecm tells the trany to go into lock up. maybe I did not explain to well. The trany goes into lockup well to early which is a common problem with earyl C4s, just looking for a way with out putting a shift kit in to delay the TCC lock up.
Old Nov 23, 2003 | 09:21 PM
CFI-EFI's Avatar
CFI-EFI
OH ! That's a totally different question. I doubt you will see any difference in the TCC operation with a shift kit. That IS an ECM contralled operation. Most chips will alter the TCC activation points. That is about ALL the one I bought did, except make my 1/4 mile times a little slower. Other than a chip, you could install a manual switch. Good luck, and...
RACE ON!!!
To ECM Chip to change shift points
