help!! 94 lt-1 passenger cat.
Old Nov 24, 2003 | 04:13 PM
fiddleplayer's Avatar
fiddleplayer
Default help!! 94 lt-1 passenger cat.
Why are there two O2 sensors on the passenger side cat? One is in front of the cat the other after. The direct replacement cat I received today has only one bung. IT'S ALWAYS SOMETHING!!!
FP
Old Nov 24, 2003 | 04:41 PM
-=Iron Mike=-'s Avatar
-=Iron Mike=-
Default Re: help!! 94 lt-1 passenger cat. (fiddleplayer)
I've never looked before. That is my next job though, I think my cat has completely gone south......makes a hell of a noise under load. Is it a GM relacement part you picked up? Sounds awfully curious to me.
Old Nov 24, 2003 | 05:29 PM
fiddleplayer
Default Re: help!! 94 lt-1 passenger cat. (Irish Mike)
I got them from discount converter in houston. Catco is the brand name. It said it was a direct replacement. I even called and told them it was a 94 corvette LT-1. The pipes are smaller than the stock vette converters so it will probably be restrictive. If I had seen them first I would not have bought them. I took the pasenger side to a muffler shop and had anouther bung added. $20!! I should have gotten the sound car or the random cats.
Oh well, such is life.
FP
Old Nov 24, 2003 | 06:31 PM
fiddleplayer
now the flanges on the passenger side are 1/2 a hole off, and the driver's side, besides being 1/4 hole off also hit the motor mount bolt. The rear flange on the drivers side is supposed to be tapped, well, it's not. The holes are too big to tap for the existing bolts. 42 miles round trip to the parts store. I'm sending these back. :mad :mad :mad :mad :bs :bs
Old Nov 24, 2003 | 07:24 PM
BAM92's Avatar
BAM92
96's had 2 o2 sensors on passenger side. The others had only one.
Old Nov 24, 2003 | 08:37 PM
fiddleplayer
Default Re: help!! 94 lt-1 passenger cat. (BAM92)
It is definately a 94. Door sticker is april of 94. There are definately two O2 sensors on the pasengers side. It's laying on my garage floor.
Anyone know why there are three on this car?
FP
Old Nov 24, 2003 | 08:41 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
1984-1990 had one O2 sensor, 1991-1993 had two O2 sensors, 1994-95 had three. 1996 had 4.
This was done(94-95) in preparation for OBD II which started in 1996.
Old Nov 24, 2003 | 10:58 PM
Goody's Avatar
Goody
Like Mojo said, because it's supposed to be there. Spend the big bucks and buy the random tech cats. Straight bolt in ($250ea) or universals ($170ea) your choice.
Old Nov 24, 2003 | 11:56 PM
tjwong's Avatar
tjwong
I got a complete set of both GM cats with only 8000 miles on them if you want them email me.
Old Nov 25, 2003 | 11:22 AM
fiddleplayer
Default Re: help!! 94 lt-1 passenger cat. (tjwong)
Goody, Big bucks is right. $365 from random tech directly not $250.
TJ - thanks anyway. I ordered the random tech's. The OEM's are very heavy and since I'm already there, I may as well increase the exhaust flow.
Old Nov 25, 2003 | 10:36 PM
VMAX451's Avatar
VMAX451
:yesnod: A couple of years ago I replaced my driver's side cat with a CATCO direct fit. It had misaligned bolt holes on the front flange and non-tapped holes in the rear flange. I see nothing has changed since then. :bs :bs :bs :mad
Old Nov 25, 2003 | 11:17 PM
Goody's Avatar
Goody
Go to Tbyrne motorsports on this site (supporting vendor) and look under C4 exhaust and they are $250 each.
Old Nov 26, 2003 | 08:15 AM
fiddleplayer
Default Re: help!! 94 lt-1 passenger cat. (Goody)
Thanks. I already ordered them from random. I will certailnly look there next time. The story of my life...always a day late.
To help!! 94 lt-1 passenger cat.
