Changing clutch cylinders
Old Nov 25, 2003 | 11:25 AM
Storz's Avatar
Storz
Default Changing clutch cylinders
how hard is this job? I am ordering new master/slave today and just would like to have an idea of how long itll take, its for my 87
Old Nov 25, 2003 | 09:30 PM
froggy47's Avatar
froggy47
Default Re: Changing clutch cylinders (Storz)
ttt
Old Nov 26, 2003 | 11:44 AM
c4cruiser's Avatar
c4cruiser
The slave is pretty easy. A pin connects the actuating rod to the clutch fork, couple bolts hold the cylinder to the bellhousing and one bolt holds the hose ammembly to the slave housing. Once you get under the car, the slave should be off in just a minute or so. It's probably a good idea to let all of the old fluid drain out before you begin to pull the master.
The M/C is a little more difficult. A pin holds the cluth pedal shaft to the M/C actuating rod and that's up under the dash. Pull the "hush panel" under the steering wheel for access. The nuts holding the M/C to the firewall are removed and the hydraulic line is removed. Use a line wrench here- you don't want to bung up the fitting!! From what I have searched, the hydraulic line is no longer available from the dealer and I have not even seen it at various parts places so treat that piece like gold :D
With everything back in place, bleed the system by holding the slave parallel to the ground and open the bleed valve to bleed the system. Use either a good DOT3 brake fluid or the GM clutch fluid. A pint should do it.
To Changing clutch cylinders
