Replace hood release cable
Old Nov 25, 2003 | 12:35 PM
Clark's Avatar
Clark
Default Replace hood release cable
Anyone do one of these? Is it difficult? When putting away my 89C4 for the winter, I couldn't get the hood open. After using up my entire vocabulary and a few tricks, I got it open. Passenger side cable shot. Replacement part is $48 and on order, but what can I expect putting it in? Any hints?
Thanks in advance to all.
Old Nov 25, 2003 | 12:54 PM
LoneStarSoldier's Avatar
LoneStarSoldier
Default Re: Replace hood release cable (Clark)
I'll ride this one with you if it's ok. Just bought a new GM cable set off Ebay and was building up the courage to tackle the installation. Couldn't be any harder than putting the Amp relay in for the Bose radio in.
HAVE A GREAT DAY!!! :flag
Old Nov 25, 2003 | 02:31 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Not a big job... if you look in the tech tips, you'll find an emergency mod for just this type of issue... check it out, total cost $4... and can save all the extra language u used...
Old Nov 25, 2003 | 03:12 PM
ElisTwoCents's Avatar
ElisTwoCents
St. Jude Donor '05 thru '24
Default Re: Replace hood release cable (vinnies87)
I have a cable in the box waiting to be put in my 87 and was wondering the same thing...
Old Nov 25, 2003 | 03:39 PM
HeeHaw89's Avatar
HeeHaw89
Default Re: Replace hood release cable (2nd2SEX)
Heh, subscribing...I may need to replace mine if I can't get it adjusted correctly :cuss
Old Nov 25, 2003 | 08:39 PM
Strick's Avatar
Strick
This sounds like a preventive maintenance item that we all should do. I have that tool, but I don't want to have to use it. So, I'll be watching this thread, also. :lurk:
Old Nov 26, 2003 | 11:33 PM
Clark's Avatar
Clark
Default Re: Replace hood release cable (Strick)
So, we're all interested, but nobody's done it. Not quite the response I hoped for. I just got the cable today.
Anybody know anything? Anyone?
Buehler?
Old Nov 27, 2003 | 05:18 PM
JAKE's Avatar
JAKE
A buddy of mine replaced mine while I was working on something else. Took less than half an hour. Hardest part was being upside down under the dash.
I've since installed cable ties as a back up in case the stocker breaks again I can just give the ties a yank to pop open the hood.
It actually takes a lot longer to "fish" open the hood when the cable breaks than it takes to install a new cable. Easier too.
Jake
[Modified by JAKE, 4:20 PM 11/27/2003]
Old Nov 27, 2003 | 05:53 PM
vinnies87's Avatar
vinnies87
Here's a pic of my setup...
used picture hanging wire and wire connectors...
Ran the loop under the plastic by the wipers , tucked away till needed... they work fine
[Modified by vinnies87, 2:54 PM 11/27/2003]
Old Nov 28, 2003 | 09:35 PM
RonJ's Avatar
RonJ
Super pic ... guess I know what I'll be doing shortly ... TY!!! :D
Old Nov 28, 2003 | 11:45 PM
Clark's Avatar
Clark
Default Re: Replace hood release cable (JAKE)
Jake
Thanks for the reply. How in the heck did your buddy even get at the grommet under the dash in 1/2 hour? I spent the afternoon today disassembling everything on the inside just to get a peek at it. It's way up there, and I can't get a tool on it. In the past, I've replaced my clutch master cylinder, my starter clutch pedal interlock, and I've had the steering column out, so I'm familiar with the area, but wow! How do you do it?
Old Nov 28, 2003 | 11:52 PM
Clark's Avatar
Clark
Vinnie
I'm gonna do the mod as you show it. Thanks for the great picture. If I understand correctly, you loop one end of the cable around the lever or actuator that the normal cable pulls to release the hood, right? You crimp it at that end so it stays on the little lever or whatever it is. Then you drill a hole thru the rail, run the cable thru it and then make a big loop that you release by hand by reaching under the hood.
Old Nov 29, 2003 | 05:26 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Just one of the nightmares on my C4.
Good Luck
tony
:flag
Old Nov 30, 2003 | 11:34 AM
Oly's Avatar
Oly
Thanks Vinnie, looks like I have a good evening project to do.
:thumbs:
Old Dec 1, 2003 | 02:09 PM
Clark's Avatar
Clark
Default Re: Replace hood release cable (Oly)
Ok, the 2 emergency releases are done. I didn't have the cool crimping tool that Vinnie had, and Home Depot had the wire rope but not the correct size ferrules and had no crimping tools. So I used the wire rope (aircraft cable, braided steel cable--stainless would've been nice) and made the same setup like Vinnie did, but I formed the loop with electrical tape and then zip-tied the heck out of it on each end. A-ok!
But I still want to put in the factory hood release cable. I'll leave the emergency in, but it's still a pain to install. Any ideas?
Old Dec 1, 2003 | 03:37 PM
Southern Comfort's Avatar
Southern Comfort
Smooth move Vinny.... :thumbs:
Old Dec 1, 2003 | 03:42 PM
scorp508's Avatar
scorp508
I've replaced mine. It isn't all that hard. I think I fought more with getting the cables to stay in the release handle than anything else.
To Replace hood release cable
Old Dec 1, 2003 | 09:58 PM
Clark's Avatar
Clark
Default Re: (scorp508)
Hey Scorp
Thanks for weighing in. Did you pull the unit into the interior of the car, or did you yank it out on the engine compartment side?
Did you fish the new cable thru the existing grommet or did you install the entire kit? The part I got is an entire assembly including the grommet. The grommet is what I can't get out of the firewall. What did you use to get the grommet out of the firewall? Thanks.
Old Dec 1, 2003 | 09:59 PM
scorp508's Avatar
scorp508
Default Re: (Clark)
I think I may of just pulled the grommet into the car until it finally broke and gave way. I then fished the lines from inside the car into the engine bay.
Old Dec 1, 2003 | 10:48 PM
85vet's Avatar
85vet
Cruise-In V Veteran
If you are replacing the rubber - just cut it out.
That is the hardest part of the job.
