Fuel filter what a differance!
Old Nov 25, 2003 | 07:58 PM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
Default Fuel filter what a differance!
Just got the fuel filter changed and what a change, and all this time I thought the opti was going bad. Lesson all ways change the filter before condemnimg the opti spark!
Old Nov 25, 2003 | 08:57 PM
1996man's Avatar
1996man
Default Re: Fuel filter what a differance! (grapeknutz)
when you say change what exactly do you mean? performance? soomter running? you say you thought it was the optispark at first i am just curious what symptoms you had that it cured
Old Nov 25, 2003 | 09:29 PM
JB666's Avatar
JB666
What was it doing, cutting out at higher rpms? Stumbling a bit at idle?
I've been tempted to do the filter myself, since there has been a string of bad gas around here this past year, this may make my decision easier.......
Plus tonight I did something I NEVER do.. I let the gauge get to RESERVE, and when I punched it on the way home, the motor cut out from under me above 3500 RPMS... OOPS, I don't like sucking from the bottom of my tank!!
Old Nov 25, 2003 | 09:33 PM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
Default Re: Fuel filter what a differance! (1996man)
I had a miss under heavy load , like a cyl or cyls was cutting out, what had happened the fuel pressure was dropping due to a plugged filter.
I bought the car and was still chasing "demons" so it was a prosess of elmination Now it pulls at all loads with no complaint.
Old Nov 25, 2003 | 11:21 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
How many miles on the car prior to the fuel filter change?
Old Nov 26, 2003 | 12:07 AM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
Default Re: Fuel filter what a differance! (tobijohn)
112000 Which is embarrassing not to think of it sooner!
Old Nov 26, 2003 | 12:12 AM
tobijohn's Avatar
tobijohn
Bench Racer
Yikes! Do you think the one you replaced was the original?
Old Nov 26, 2003 | 12:21 AM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
YUP!!
To Fuel filter what a differance!
