Antena change/rubber plug
Old Nov 25, 2003 | 11:07 PM
dburgjohn's Avatar
dburgjohn
Default Antena change/rubber plug
I had to remove the antena from my 92. The rubber plug where the wire goes inside almost did not come out. Any ideas on how to put it back now?
Old Nov 26, 2003 | 05:23 PM
85blkZ51's Avatar
85blkZ51
Default Re: Antena change/rubber plug (dburgjohn)
Are you talking about a groument through a bulkhead? If so, try some WD-40 or grease on the plug and work it back in the hole with a flat screwdriver.
Old Nov 27, 2003 | 03:32 AM
dburgjohn's Avatar
dburgjohn
Default Re: Antena change/rubber plug (85blkZ51)
That is the one. The space is just so tight around it. I had to use a long extension to knock it out. I am a big guy and my hands do not fit up where the plug goes in. Wonder if there is some GM tool ($$$$) that does the job <G>.
Old Nov 27, 2003 | 10:08 PM
sraft's Avatar
sraft
If you're not gaining access this way already, I recommend that you remove both tail light assemblies from the left side. Take out the lisence plate & backup lamp for access to the inner, them use that hole to remove the outer. The grommet will be easily accessible. The bolts that hold the antenna mounting bracket are pretty accessible also.
I lubricated the grommet with a little vaseline and it slipped right in. With the tail lamp out you can push and twist the grommet from the outside, while gently pulling the wires from the inside.
Old Dec 7, 2003 | 09:52 AM
dburgjohn's Avatar
dburgjohn
OK everyone, here is the trick! Hold the rubber plug under running hot water (hot as you can). When it is really warm and soft, spray a little (very little) WD-40 on it. The plug will go right in.
:party:
[Modified by dburgjohn, 8:53 AM 12/7/2003]
Old Dec 7, 2003 | 01:12 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Read where it says to remove the rear wheel, then the splash guard to make removal and install easier.... did you have to do that?
Have a new one, but haven't replaced yet...
Old Dec 7, 2003 | 01:55 PM
RutsRup's Avatar
RutsRup
Default Re: Antena change/rubber plug (vinnies87)
Removing the wheel and the wheel well doesn't help in reinstalling the grommet, there's absolutely no leverage. You need hands like Superman to get the grommet back in.
Old Dec 7, 2003 | 02:04 PM
vinnies87's Avatar
vinnies87
Default Re: Antena change/rubber plug (RutsRup)
Not talking about the grommet install.... :lol: talking about the whole install of new antenna :thumbs:
Old Dec 7, 2003 | 10:05 PM
dburgjohn's Avatar
dburgjohn
Other than the rubber plug, the job was easy, less than 30 min total (not counting the seven days between removel, order new and new arrive)
Old Dec 8, 2003 | 01:17 AM
Todd15's Avatar
Todd15
how much was the new antenna?
To Antena change/rubber plug
