75/25 Coolant Mix
Old Nov 26, 2003 | 11:45 AM
Bill-35thAnvrsy-88's Avatar
Bill-35thAnvrsy-88
Default 75/25 Coolant Mix
I'm using a 75/25 coolant mix (with Water-Wetter) for more than obvious reasons. If I use my block heater, then start and warm up the car in the garage to about 150 degrees with it below freezing outside, is it OK to drive the car with this mix in the winter or is it safer just to increase the coolant? I don't run her too much in the winter just a weekly spin.
Thanks!
Bill
Old Nov 26, 2003 | 12:25 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: 75/25 Coolant Mix (Bill-35thAnvrsy-88)
That should be OK. Just don't park too long at your destination when it's too cold out. A 25% antifreeze solution should give you protection to about 10* above zero. Unless it's really cold out, the long warm up isn't necessary. Good luck, and...
RACE ON!!!
Old Nov 26, 2003 | 01:03 PM
tjwong's Avatar
tjwong
Bill there isn't any problem running that mix. The only problem I would worry about is freeze protection. During the really cold days when there is a risk of block freezing I am sure that you would probably have that block heater plugged in, right? :)
[Modified by tjwong, 10:03 AM 11/26/2003]
Old Nov 26, 2003 | 01:23 PM
c4cruiser's Avatar
c4cruiser
Factory fill calls for a 50/50 mix which should get your freezing protection down to -35 deegrees. The additional coolant should also increase the anti-corrosion protection. With the car in the garage, you shouldn't really need a block heater unless it helps to start the car easier or the temps do get below zero.
One thing that is very important is to get the oil up to normal operating temperatures. Any condensation inside the motor may not get removed if the oil and water temps aren't up to normal for a period of time. I would drive around for around 20 minutes after oil temp is up to normal. There will be moisture in the exhaust system, too. Getting the exhaust system hot will burn off any moisture and increase its life.
Old Nov 26, 2003 | 03:35 PM
TreyZ28's Avatar
TreyZ28
why do you need a block heater? are in alaska or something?
Old Nov 27, 2003 | 03:50 AM
JAKE's Avatar
JAKE
Default Re: 75/25 Coolant Mix (TreyZ28)
I've read that anit-freeze also serves as a water pump lubricant. Does 25% seem to be enough that purpose?
My opinion, 50/50 all the time. Why take unnecessary chances.
Jake
Old Nov 27, 2003 | 07:34 AM
larryfs's Avatar
larryfs
Default Re: 75/25 Coolant Mix (c4cruiser)
50/50 is = to -20F
if you live in FL 75/25 is ok
Old Nov 27, 2003 | 06:13 PM
VettBrat's Avatar
VettBrat
When I was young, oh so long ago, I got in my car without warming it up. It had 25% antifreeze. It was about 10 degrees outside and I promptly froze my radiator........solid.
Old Nov 27, 2003 | 06:33 PM
scorp508's Avatar
scorp508
You use a block heater in Virginia? :confused:
Old Nov 27, 2003 | 07:27 PM
TheStef's Avatar
TheStef
Default Re: (scorp508)
I put straigh coolant in my cars.... never had a problem? can I ask why people mix in water with the coolant? is this better?
Old Nov 27, 2003 | 07:39 PM
scorp508's Avatar
scorp508
Default Re: (TheStef)
Water cools waaaaaaay better than antifreeze does, but it also freezes and boils which is bad living in cold climate areas and high running temps. Antifreeze both lowers the freeze point and raises the boiling point when mixed together. You get less cooling, but more protection.
Old Nov 27, 2003 | 08:03 PM
CFI-EFI's Avatar
CFI-EFI
After the solution reaches 70% antifreeze/30% water, the freezing point starts to rise and the boiling point becomes lower. A 50/50 mixture protects down to -34* F (not just -20*). A 70/30 (70 antifreeze) is good down to about -66* F. 100% antifreeze costs more and protects less than the appropriate mixture. If *I* needed more than a 50/50 mix, I'd be moving. Remember, too the freezing point has nothing to do with "wind chill". Good luck, and...
RACE ON!!!
PS. My numbers came from an ethylene glycol container. Dex Cool may be different.
Old Nov 27, 2003 | 09:11 PM
TheStef's Avatar
TheStef
Default Re: (CFI-EFI)
I'm canadian.. I wish I could live in a warmer place.. but hmmmm I don't even drive the car during winter, so I should add water.
Old Nov 27, 2003 | 09:19 PM
CFI-EFI's Avatar
CFI-EFI
I don't know the freeze point of straight antifreeze. Unless you live near the arctic circle, I would think you are adaquately protected. I wouldn't add water, at this point, unless it's low on coolant, but you CAN protect it better for less money, next time. Good luck, and...
RACE ON!!!
Old Nov 27, 2003 | 09:27 PM
TheStef's Avatar
TheStef
What is the recommended mixture? 25/75 ?
Old Nov 28, 2003 | 03:05 AM
skeet's Avatar
skeet
Good question. Almost all manufacturers, including the Corvette, leave the factory with a 50/50 mixture-even cars going to dealers in Florida (good to -34). It is as much for corrosion protection as freeze/boil protection. I have changed the anti-freeze yearly in the 85, 88 and 95 and all the internal radiator fins are bright and shiney with zero corrosion. I can not look into the 95's radiator but I am sure it is the same. Shows how well this mixture and yearly flushes can keep a 19 year old radiator/system looking like new. It is the first thing I look for when buying a used Vette. Tells me if the car was REALLY well cared for rather than what the seller says.
Just replaced the anti-freeze with the new and better G-05 anti-freeze. Anyone else using this new stuff? It has been used and proven in europe. It will mix with the green but not Dex. Can be used in a clean Dex system. Offers better corrosion protection.
Old Nov 28, 2003 | 10:03 AM
Bill-35thAnvrsy-88
Ok, so the consensus is, yes I'm protected enough to drive her around (here in Virginia...temps rarely go below 10* but below 32* is typical in Virginia in dead of winter) but I do have less water pump lubrication and corrosion protection. But...doesn't water-wetter increase the lubrication and corrosion resistive properties since those who use it typically run less anti-freeze anyway to reduce operating temps? I just don't remember.
Thanks!
Bill
To 75/25 Coolant Mix
Old Nov 28, 2003 | 08:04 PM
CFI-EFI's Avatar
CFI-EFI
The potential problems aren't with the driving. It's between drives that you have to be concerned with.
I'll be interested in further responses on the Water Wetter question. This spring, my track outlawed antifreeze. I ran pure water and a bottle of Water Wetter (allowed). With semi-annual flushes, anitfreeze out in the spring and back in, in the fall, I'm not too worried about corrosion, but I would like input on the water pump lubrication question.
Bill, A 50/50 mix is pretty well considered a "universal" solution, except in extreme conditions where more protection is required. Previous to the new track rule, I have always flushed my cooling system bi-annually. I have the origional radiator core, still in good shape. Good luck, and...
RACE ON!!!
Old Nov 28, 2003 | 09:02 PM
RonJ's Avatar
RonJ
With marginal anti-freeze protection and outside temperature around freezing or slightly above, I've seen radiators freeze up if you are on the road before the thermostat opens. Has to be the wind chill effect through the rad.
For the price of anti-freeze, go 50/50. My 2 cents!!
Old Nov 28, 2003 | 09:20 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Default Re: (RonJ)
is that enough to keep your heads from corroding?
