MAF question
Old Nov 26, 2003 | 06:21 PM
VettBrat's Avatar
VettBrat
Default MAF question
I am pulling a trouble code of 33. I went to Autozone and they tell me it is a MAF or a ECU. Any easier, as in less expensive, places to look before I start spending money?
Old Nov 26, 2003 | 09:27 PM
vader86's Avatar
vader86
Default Re: MAF question (VettBrat)
First replace the two relays behind the battery on the firewall, they are about $20 together.
Reconnect the battery and see if the code returns.
If it does, then its the MAF sensor. ECM failure is highly unlikely
Old Nov 26, 2003 | 10:50 PM
VettBrat's Avatar
VettBrat
Default Re: MAF question (vader86)
Thanks, I will try the relays first. On my daughters Dodge they "cleaned" the MAF sensor? Does that make any sense?
Old Nov 26, 2003 | 11:06 PM
88_vette's Avatar
88_vette
Yeah unplug the MAF if the car is not running or is running rough. If the car runs better than it's a bad MAF> You will need to replace the two relays if you replace the MAF anyway
Old Nov 28, 2003 | 10:52 AM
VetBoy89's Avatar
VetBoy89
I suffered from the dreaded code 33 syndrome for over a year. Try those two relays first, they are only about $10 each; replace both of them at the same time. If the problem still occurs (like mine did) try replacing the TPS.
I replaced relays, the MAF and the ECM...nothing helped. Then finally one day I was messing around and decided to test my TPS, at WOT it would only read something like 3.45v so I replaced it and my code 33 has never returned and it's been about 35,000 miles since. :thumbs:
Old Nov 28, 2003 | 04:00 PM
VettBrat's Avatar
VettBrat
Thanks for the advice. It was the burn off relay. $10 fixed the problem and I learned a little about my new toy in the process. :)
Old Dec 1, 2003 | 01:12 PM
VetBoy89's Avatar
VetBoy89
:hurray: Cool. But just remember, that Code 33 can be intermittent and a real PITA.
Hopefully that fixed your problem, most of the time it does.
You might want to pick up an extra one of those relays and throw it in the toolbox. It's cheap insurance and that same relay is used in several places in your car...fuel pump relay, fan relay, etc. :thumbs:
To MAF question
