Steam Cleaning
Old Nov 30, 2003 | 06:51 PM
CORVETTE GURU's Avatar
CORVETTE GURU
Default Steam Cleaning
How Safe is it with the sensative Opti Spark? also considering the 96 is vented
Old Nov 30, 2003 | 07:02 PM
scorp508's Avatar
scorp508
You're the guru, shouldn't you know? :jester I would be sensitive in the area of hte opti, otherwise you'll probably be ok. Steam itself (which is invisible) is extremely hot, I would test it on some vacuum line away from the car first to make sure it won't melt it.
Old Nov 30, 2003 | 07:04 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Default Re: (scorp508)
Steam is pretty pervasive, I wouldn't even risk it.
Old Nov 30, 2003 | 07:59 PM
bigjack's Avatar
bigjack
Default Re: Steam Cleaning (CORVETTE GURU)
I've always used Gunk brand cleaner. Large amounts can be prepared by mixing the straight solution(avail. in qts.) with, I believe kersosene. It can then be added to a spray atomizer(Windex type sprayer) . Spray onto a warm engine and work especially dirty areas with an old paint brush(trimmed to get stiffness). Rinse with a gentle garden hosing. This allows greater direction and control over the process. Same stuff is avail. in spray cans if you don't need much/want to mix. Steaming might better be reserved for out-of-the-car, heavy duty cleaning. Just my thoughts. Jack
Old Nov 30, 2003 | 08:20 PM
Strick's Avatar
Strick
I use a presure washer, BUT ONLY AFT OF THE VALVE COVERS ! Even though I have sealed the opti and vented it, I don't get the front of the engine wet. With the Vette up on the Qwik-Lift, I use the pressure washer to clean the underside. Only had to do it once since I bought it. Hot steam would worry me. :skep:
Old Nov 30, 2003 | 09:22 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Default Re: Steam Cleaning (Strick)
Tom, have you been using the cold steam? :lol:
Old Nov 30, 2003 | 09:29 PM
Strick's Avatar
Strick
Default Re: Steam Cleaning (Ramrod92)
Hot steam would worry me. :skep: Tom, have you been using the cold steam? :lol:
Don't I feel smart :banghead:
Old Nov 30, 2003 | 09:54 PM
CORVETTE GURU
haha thanks everyone.. HOT steam crossed my mind.. but i thought to myself.. the plastics are under the hood laying around when the engine is hott anyways.. i should be able to take the steam right?? a respectible automotive technology teacher i spoke with told me it works great.. and he said just work around and careful in the front areas of the engine
Old Nov 30, 2003 | 09:57 PM
Strick's Avatar
Strick
Well, Good luck with it. Tell us how it works out.
To Steam Cleaning
