Ran into problem doing TB Bypass.. Help!
Old Dec 1, 2003 | 08:00 PM
JB666's Avatar
JB666
Default Re: Ran into problem doing TB Bypass.. Help! (Trog)
Yeah, mine ended up costing $0..
I called ZIP today, and told the guy what I found, about the two lines being the same size, and he said "Oh yeah, some were ordered that way". ORDERED?? I really can't see someone standing in the Chevy dealership:
Salesman: Would you like any other options before we place the final order?
Buyer: Yes, I would like to have matching size coolant lines coming from my TB, just something I always wanted.
Salesaman: Well, we can do that for you!
:rolleyes:
Old Dec 1, 2003 | 09:43 PM
4-ACES's Avatar
4-ACES
From: Northern KY.... Just 3 hours to Las Vegas in a 767
Default Re: Ran into problem doing TB Bypass.. Help! (Jbaker)
I think the most effective way to do this TB Bypass is to not bypass it at all. Throw away the kit. Remove the 2 coolant lines that attach to the TB and PLUG them.
Even better , remove the 2 Tees in the coolant supply and return lines completely and replace with straight through connectors. By attaching the 2 lines that went to the TB together with this kit , you are actually allowing a small a mount of coolant to short cycle the radiator and not flow through the engine block. What you gain in cooler air to the TB you loose in shorting the engine of coolant. Plug em. Works fine.
Old Dec 1, 2003 | 09:48 PM
Strick's Avatar
Strick
Default Re: Ran into problem doing TB Bypass.. Help! (4-ACES)
How does your heater work? :skep:
Jeff, you have mail.
[Modified by Strick, 9:51 PM 12/1/2003]
Old Dec 1, 2003 | 10:17 PM
4-ACES's Avatar
4-ACES
Default Re: Ran into problem doing TB Bypass.. Help! (Strick)
[QUOTE]How does your heater work? :skep:
OH.......you want heat too? Just take out the plugs and reattach to the TB. :)
You're right .....I should have started with " If you live in a warm climate and don't need your heater"
Old Dec 1, 2003 | 10:47 PM
Strick's Avatar
Strick
Now you have me thinking. What if you put a ball valve inline to the heater core and in the summer, turn it off, and in the winter, turn it back on. This would stop some of the heat that is always in the heater core which is inside the car. Hummmmmmmmmmmmmmmmmm.
Old Dec 2, 2003 | 12:40 PM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
I do not agree with this. The coolant needs to flow. Just my .02.
Anyway, on my 92 the hoses were different sizes. I just made a "connector" for them. I left the holes that go "through" the TB open. No real need for caps. Jeff, did you finally just put in a new piece of hose? Seems like the easiest way to me. Hope you got it taken care of!
-Rick
Old Dec 2, 2003 | 01:17 PM
JB666's Avatar
JB666
Default Re: Ran into problem doing TB Bypass.. Help! (cicch95)
-Rick
Yes, that's all I ended up doing. I'm sending the 'kit' back to ZIP for a refund... That'll teach me to LOOK next time!!
Old Dec 2, 2003 | 03:38 PM
warren s's Avatar
warren s
http://home.si.rr.com/c4s4ever/
Check my link above ^^
Old Dec 2, 2003 | 05:28 PM
QuikZilver's Avatar
QuikZilver
Default Re: Ran into problem doing TB Bypass.. Help! (warren s)
Jbaker, I didn't see that anyone commented about the PCV Valve in your request. On my 93, it is under the fuel rail cover on the driver side. It is right on the intake manifold and has a U-shaped hose connecting the PCV Valve back to the intake manifold. I finally found mine too (by mistake, I thought it would have been on the passenger side and thought maybe the original owner ordered it without a PCV Valve, like your original owner ordered yours with the same size TB collant hoses :D .) When I pulled the hose off of the PCV Valve, the hose fell apart. Check to see who bad your hose is before you pull it off. You may want to pick up a new one from the dealer. The hose is around $5. Good luck.
:cheers:
Old Dec 2, 2003 | 07:43 PM
SouthernSon's Avatar
SouthernSon
Default Re: Ran into problem doing TB Bypass.. Help! (Whitvette)
DON'T PLUG UP THE HOSES!! The vent from the back expels any trapped air, from time to time, up from the rear and back into the radiator. One does not want trapped air in the heads!
Old Dec 2, 2003 | 09:57 PM
JB666's Avatar
JB666
Default Re: Ran into problem doing TB Bypass.. Help! (southern_son)
Thanks for all the help & advice here guys...
Strick, thanks for those pictures, it helped me decide my next step, too!
I'm curious if ALL '95's now, have the same size coolant lines? If so, it'd a fairly straight forward job! Now all I need to do is bleed the system.. But, I'm not going anywhere, since this white crap just started falling out of the sky :mad ... She's sleeping now.
Old Dec 2, 2003 | 10:03 PM
Strick's Avatar
Strick
I'm glad you didn't use that four letter word describing falling frozen precipation. Even in the Carolinas it trys to sn_w. Makes me wonder if I moved far enough south. :skep:
Old Dec 3, 2003 | 09:20 AM
  #33
cicch95's Avatar
cicch95
Oh man Jeff...if it is snowing up there it won't be long for it to get down here to RI! :(
See ya in the spring!! :D
-Rick
Old Dec 3, 2003 | 09:29 AM
  #34
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
Mr. Baker
I am Justin Abbott with Zip Products, I would like to aplogize for what was explained to you about your problem. We pride ourselves on our customer service and the satisfaction of our customers on the parts they recieve. Please send the part back that is wrong attention to Justin Abbott and I will make sure you get your refund and refund on the shipping plus a $10 gift certificate. I am truly sorry that one of our salesman said this to you and I will take care of it.
Thank you
Justin Abbott
Old Dec 3, 2003 | 09:38 AM
  #35
Strick's Avatar
Strick
Default Re: Ran into problem doing TB Bypass.. Help! (jabbott)
Mr. Baker
Thank you
Justin Abbott
Doesn't this just make you want to buy from these guys? It is so refreshing to hear things like this. Here's to you Justin :cheers:
Old Dec 3, 2003 | 09:42 AM
  #36
JB666's Avatar
JB666
Mr. Baker
Thank you
Justin Abbott
That is an excellent response, and I appreciate you coming out here and answering this... Thank you!!! :cheers:
You just got my future orders, too.
Old Dec 3, 2003 | 10:20 AM
  #37
Caboboy's Avatar
Caboboy
Hi Jeff, long time no talk! Hope this is finally worked out for you :seeya
I am now a ZIP customer too after reading Justin's post.....how nice that was of him :cheers:
Old Dec 3, 2003 | 05:23 PM
  #38
HiRiser's Avatar
HiRiser
Default Re: Ran into problem doing TB Bypass.. Help! (Caboboy)
Instead of all the monkey business with adaptors and plugs use a 96 upper radiator hose and 96 heater hose
PN 10262505 & 10257252 ( I think, been a couple of years and reciept only says 'hose')
Old Dec 3, 2003 | 08:07 PM
  #39
JB666's Avatar
JB666
Hey!! All has worked out..
I'm sending the kit back with UPS Friday, and am glad to still be doing business with ZIP.. It's tough, when your in this business, if you get one saleperson who just doesn't care, and will tell you anything they THINK you want to hear... It can damage a company's reputation. I've bought a lot through them in the past year, and will be buying plenty more in the future!!!
