Front Lowering Wedges
Old Nov 30, 2003 | 09:01 PM
BLESSED427's Avatar
BLESSED427
Default Front Lowering Wedges
Hello,
I have purchased the rear bolts and the front wedges to lower our 89 coupe, my question is do I have to remove the front spring completly in order to install the wedges, and do I need a spring compressor for the spring or can I do it with my regular shop tools?
Paul
Old Nov 30, 2003 | 09:42 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: Front Lowering Wedges (BLESSED427)
Hey Paul,
Welcome to the :party:
I would say yes, you need to remove the spring. At least free it from one knuckle at a time. I don't think you will be able to get at the mounting points for the shims unless you do. Others should chim in on this as this is a very popular mod............
Old Dec 1, 2003 | 09:59 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Yes you have to remove the spring. Get your car up as high and safe as humanly possible. You don't have to use a spring compressor. Ball joint puller will come in handy though. There is a tech tip in the tools section that will shed some light. Not that hard to do.
:cheers:
Old Dec 1, 2003 | 10:01 PM
BLESSED427's Avatar
BLESSED427
Default Re: Front Lowering Wedges (AGENT 86)
Thanks for the information, I will ckeck out the tool section and see what it says.
Paul
To Front Lowering Wedges
