93 water pump questions
Old Nov 30, 2003 | 09:44 PM
ritchiem's Avatar
ritchiem
Default 93 water pump questions
I just picked this up this summer and have noticed it intermittently running hot. Checked the maintenance records realized that this has had FOUR water pumps installed (Less Than 61k miles). That blows. Looks like this one's leaking also and destined to be changed also. What's the failure mode? Do the impellers wear out? Is it just a gasket leaking? Are some water pumps better than the stock ones?...I've seen some writings about the electric ones but prefer to stay stock. Any ideas on the intermittent overheating...mostly at idle. Heater often doesn't push hot air. :banghead:
Old Nov 30, 2003 | 10:42 PM
Rex Ruby's Avatar
Rex Ruby
Philly 'Burbs Events Coordinator
Default Re: 93 water pump questions (ritchiem)
When they go bad it's from the weep hole on the very bottom. Maybe the cooling system is clogged? Possibly preventing it from doing it's job and causing premature water pump failure?
Rereading your post about the heat, that sounds like a clogged up heater core. I had that and disconnected both heater hoses and flushed both ways with a hose. Took several flushes before I got a good clean stream of water. And I have heat again :cheers:
[Modified by Rex Ruby, 10:45 PM 11/30/2003]
Old Nov 30, 2003 | 10:52 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Welcome to the :party:
It's time to remove the radiator and clean out all the crap..........
Old Dec 1, 2003 | 12:43 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Re: 93 water pump questions (edsalinas)
Mine lasted 104,000 miles
Old Dec 1, 2003 | 01:07 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Here's the second one from my 92 after about 45,000. the first one also lasted about that long. Flush the heater core, clean and flush the radiator, then replace the thermostat(cheap insurance). :steering:
Old Dec 1, 2003 | 10:16 AM
dlmeyers's Avatar
dlmeyers
Default Re: 93 water pump questions (Ramrod92)
4 Pumps, wow.
I would ask if any or all were rebuilts. I have seen "remanufactured" water pumps (not LT1's) not make it out of the shop. As stated above, flush out the heater core, replace pump, thermostat, make sure you have a fresh 50/50 mix, make sure the radiator area if clean, check all hoses. After about 6 months, check the water's pH level. I believe the service manaul gives a range.
4 pumps, gotta be a reason for that.
dlmeyers 90 coupe zf6 3 speed shocks
To 93 water pump questions
