question about thermos
Old Dec 1, 2003 | 06:09 PM
Cory00's Avatar
Cory00
Default question about thermos
over here in fl. its going to get cold shold i put in a 180 or a 160 i dont have a chip so would 160 work with my system
also i think my fan is hot wired to my batt. when i turn the key on it comes on and it does not stop. its going to a little box but there is no switch to turn it on or off
right now my system starts to cool down around 215 at first start up once it hits 215 it drops down to about 200- 205 even when its about 40 out side?
thank for all the help :cheers:
Old Dec 1, 2003 | 06:16 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: question about thermos (Cory00)
What year is your car?
Several things you have mentioned seem to be a little concerning, such as fans running all the time....not having a chip....and temps going to 215.
:seeya
Old Dec 1, 2003 | 06:17 PM
Cory00's Avatar
Cory00
Default Re: question about thermos (jackdaroofer)
its a 84 auto with 113k
i mean when i first start it up when temps drop lower then 150 the temps go pretty high then start cooling down
Old Dec 1, 2003 | 06:26 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
:cheers: Still not exactly sure of what you are describing, but if the fans run continuously and the engine gets hot and then cools down, define hot and cool please.
You might want to do a thorough cooling system check including pulling the radiator and cleaning the area of trash...find out why the fans run continuously
Did you buy thei car from someone? Is it possible the seller had the fans rigged to mask a problem?
:seeya
Old Dec 1, 2003 | 06:30 PM
Cory00's Avatar
Cory00
im the 2nd owner
sorry if im not making my self clear i dont know how to explain it :confused: o well
i dont think its rigged to hide any thing but it must be like that for a reason.... my vett is going to the shop on thurs and i want the guy to do my thremo and i was gonna ask if he can rewire the fan to the thermo and make it work like it should
:cheers:
Old Dec 1, 2003 | 06:48 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
:cheers: Good Idea!! :D
To question about thermos
