rear end...
Old Dec 1, 2003 | 09:43 PM
89blkvet's Avatar
89blkvet
Default rear end...
I have an 89 vette and I would like to know how I find out which rear end gear ratio I have. THANKS !!!
Old Dec 1, 2003 | 10:02 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
Default Re: rear end... (89blkvet)
could be one of many - easiest way is to look inside the center console door and check the RPO code - For example, GM1 is 2.59's. etc. etc
here is a link for all the codes > http://www.corvetteactioncenter.com/...o/8496rpo.html
Hope it helps :cheers:
Old Dec 1, 2003 | 10:49 PM
TA's Avatar
TA
It should also be stamped on the rear, but that of course assumes no one changed the ring and pinion over the years.
Old Dec 2, 2003 | 10:32 PM
89blkvet's Avatar
89blkvet
Default Re: rear end... (TA)
Thanks for the info. I will check it out
To rear end...
