Holley Stealth Ram???
Old Dec 2, 2003 | 11:53 AM
cbrock's Avatar
cbrock
Default Holley Stealth Ram???
This manifold looks like pretty killer deal, but it says in small print: Will not fit corvette's with stock hoods. Is there anyway to get this thing to work with the stock hood? Perhaps machine down the mounting surface between the plenum and the base? I'm just wondering because the stock TPI manifold has developed a coolant leak around the base and if I'm going to go through all the trouble of pulling it off to fix it, I might as well put something better back on.
Old Dec 2, 2003 | 11:55 AM
scorp508's Avatar
scorp508
Default Re: Holley Stealth Ram??? (cbrock)
Welcome. There are solutions, but....
Old Dec 2, 2003 | 11:58 AM
Mr. Magoo's Avatar
Mr. Magoo
From: Damn taxes! Pimpin' Ain't Easy in Massachusetts
2018 C4 of Year Finalist
St. Jude Donor '03-'04-'08-'09
Do a search for Stealth Ram, you'll find more than you need to know. :jester
Old Dec 2, 2003 | 12:07 PM
VetteNoob's Avatar
VetteNoob
Don't do it!
Don't open that can back up. :nonod:
:lol:
Old Dec 2, 2003 | 03:13 PM
Curveit's Avatar
Curveit
:lol: You guys got me on the floor.
:chevy
Old Dec 2, 2003 | 07:33 PM
vader86's Avatar
vader86
:banghead:
Old Dec 2, 2003 | 07:42 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
WithOUT starting the who's plenum is better debate, has anyone actually gotten one of the custom plenum Stealths to run yet? I keep waiting for numbers, but haven't seen any yet.
Old Dec 2, 2003 | 08:07 PM
Caboboy's Avatar
Caboboy
Default Re: Holley Stealth Ram??? (scorp508)
:lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg:
Old Dec 2, 2003 | 11:20 PM
vader86's Avatar
vader86
Default Re: Holley Stealth Ram??? (flyersfan1088)
grumpyvette probably has some numbers
Old Dec 2, 2003 | 11:24 PM
scorp508's Avatar
scorp508
Default Re: Holley Stealth Ram??? (vader86)
I could be wrong, but I think everything I've seen he had were from his highly modified stroker.
Old Dec 2, 2003 | 11:35 PM
flyersfan1088
Yes, they were. A lot of guys on Thirdgen are using the Stealth, but nobody on this board seems to be using it.
Old Dec 2, 2003 | 11:38 PM
scorp508's Avatar
scorp508
Well it does fit under their hoods. (Well most of them, I know there is 1 or 2 of their hoods that don't clear.)
Old Dec 3, 2003 | 12:47 AM
red L98's Avatar
red L98
i use it and im happy with it im making lots of power :D
Old Dec 3, 2003 | 10:02 AM
HC4-Vette's Avatar
HC4-Vette
Default Re: Holley Stealth Ram??? (red L98)
wouldn't mess with it. Just wait for Jeb to finalize his custom single plane EFI. Jesse's results seems MORE than promising.
Old Dec 3, 2003 | 10:20 AM
scorp508's Avatar
scorp508
On a 434ci stroker. :lol:
Old Dec 3, 2003 | 11:20 AM
L98Terror's Avatar
L98Terror
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
stay with the tried and true,
Old Dec 3, 2003 | 11:31 AM
red L98's Avatar
red L98
On a 434ci stroker. :lol:[/QUOTE]
i also dont have the stock hood
:lolg:
To Holley Stealth Ram???
Old Dec 3, 2003 | 11:36 AM
scorp508's Avatar
scorp508
Well aren't you just a big steaming pile of helpfulness. :D
Old Dec 3, 2003 | 12:32 PM
jburnett's Avatar
jburnett
I just got an IM from Jesse...He's sending the single plane back to me with his and Corky's thoughts and I'll make the changes necessary and it will be ready should anyone want to forgoe the PITA HSR installation... I think the HSR would be a good manifold if:
1) You didn't have to get a custom plenum for it for our cars.
2) You didn't have to change the frickin' distributor.
I want to engineer a piece that will simply bolt on...You retain EVERYTHING!!! Simple, easy, straightforward... Ya know??
-Jeb
Old Dec 3, 2003 | 02:38 PM
cbrock's Avatar
cbrock
I tried to do a search just now and before I posted, all I found was a topic in the forced induction section that just meantioned using the stealth ram and not what it actually took to make it work. THEN, I saw the pull down that allows me to see the archived topics....haha, I suck.
