Please Help With over Heating Problem
Old Dec 2, 2003 | 09:06 PM
corvette33063's Avatar
corvette33063
Default Please Help With over Heating Problem
I just Bought a 1984 CFI corvette about 2 months ago Last week The car Blew the upper radiator Hose Ever since I changed that it been smelling like the car was over heating. Then the car started burning oil from both valve covers and the lower radiator hose blew. So I changed the lower hose along with the water pump. Now The Car is still burning oil and over heating also the water in the overflow tank is boiling So please help with this Big Problem.
Thanks :eek:
Old Dec 2, 2003 | 09:08 PM
corvette33063
Default Re: Please Help With over Heating Problem (corvette33063)
PS The fan turns on and off and the heater core is re-routed so I do not belive it is one of those.
[Modified by corvette33063, 2:58 AM 12/3/2003]
Old Dec 2, 2003 | 09:13 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Thermostsat stuck closed could be the culprit :smash:
Old Dec 2, 2003 | 09:59 PM
corvette33063
also i replaced the Thermostsat
help i need to get to work in the morning
Old Dec 2, 2003 | 10:12 PM
AGENT 86's Avatar
AGENT 86
You may have an airlock and or a bad rad cap. When your engine is cold open the rad cap and start your motor. Let it warm up completely then look into the rad for coolant movement. If it's present reach over and hold throttle around 2000 rpm and look back into rad. If you see coolant drop add more while holding throttle. Place cap on loosely and release throttle. In a few minutes repeat until rad is completely full. Check it again later in the day.
You may also have a ton of crap infront of radiator. You can pull the plastic shroud on top and take a look. Also test your rad cap or replace it since their cheap.
Good Luck
:cheers:
Old Dec 2, 2003 | 10:20 PM
corvette33063
ijust changed the cap but will check front of the shroud and be back in about 30min
Old Dec 3, 2003 | 01:13 AM
corvette33063
shroud is clear still hot
:U :cry
Old Dec 3, 2003 | 03:08 AM
AGENT 86's Avatar
AGENT 86
Did you look in the rad and see coolant movement ??
:cheers:
Old Dec 3, 2003 | 03:11 AM
LBC's Avatar
LBC
Have you cleaned out between your radiator and your air cond. condenser, got to remember vettes are bottom breathers they suck up every thing.Heres a link to to do the R&R on a C4 this is for a 87 but it's all the same http://www.corvettecrew.com/forum/in...y;threadid=244
Old Dec 3, 2003 | 03:24 AM
LBC's Avatar
LBC
For the oil burning whats it doing? are you adding oil all the time? does it smoke all the time?(Rings) or is it steam,(signs of a blown head gasket)Does it just smoke a little when you start it( worn valve guides and or seals)????????
Old Dec 3, 2003 | 10:03 PM
JAKE's Avatar
JAKE
:U :cry
Did you solve this?
Jake
To Please Help With over Heating Problem
