advice, opinions, and experts
Old Dec 3, 2003 | 12:28 AM
1990CORVETTE's Avatar
1990CORVETTE
Default advice, opinions, and experts
Tell Me,,, What should I start with? Air pump eliminator, pulley system, or roller rockers?
I think they all give about the same performance wise, right? :cheers:
Old Dec 3, 2003 | 12:54 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: advice, opinions, and experts (1990CORVETTE)
What other engine mods do you have so far; what is your goal?
Old Dec 3, 2003 | 10:02 PM
Curveit's Avatar
Curveit
You know they've been threatening us for years about more extensive smog checks here. I made sure my headers had air fittings when I ordered them, about 3 yrs ago. I'd be concerned about removing the air pump, even though it really cleans up the engine. Pully replacement is kind of "iffy" here on the forum. Some say 5-10 HP, some say not worth the potential cooling, Alt.charging problems, and $$$. Rockers are a bit of work, and you really need to change springs too. Possibly added more to the to the confusion than helped. Good luck with whatever you decide.
:chevy
Old Dec 4, 2003 | 09:04 PM
tkrussell's Avatar
tkrussell
For cleaning up the visual of the engine bay, removing the AIR pump and hardware. HP gain is 5 or so. Hard to feel a difference.
Roller rockers add HP at the top, but don't do much for low torque. Again, hard to feel. Not much bang for the bucks.
For overall performance gain, I'd start with getting cold air to the engine. Even in the summer, outside air is 50 degrees cooler
Consider 3.73 rear gears (on a 6sp)? Real seat of pants difference.
Old Dec 4, 2003 | 10:47 PM
JAKE's Avatar
JAKE
Of the three things you listed, roller rockers are the way to go.
No, they do not all give the same performance improvement. RRs will give you the most bang for the buck.
Jake
To advice, opinions, and experts
