Flywheel balancing?
Old Dec 3, 2003 | 09:29 AM
Strick's Avatar
Strick
Default Flywheel balancing?
I'm just full of questions, today. Okay, let's talk about the LT1 and the OEM dual mass flywheel and changing to a Fidanza dual mass aluminum flywheel. Fidanza says to bring the flywheels to a machine shop and have them match balance the Fidanza wheel to the OEM wheel. First of all, I haven't found a machine shop that does this and, second, has anybody done this?
Old Dec 3, 2003 | 10:07 AM
bogus's Avatar
bogus
Default Re: Flywheel balancing? (Strick)
you do have to do something....
the flywheel is the other half of the balance matching that goes with the internal balancing of the LT1.
if you don't do this, it will vibrate... badly.
keep looking... you may have to ship them somewhere. check with you local hotrod shops, see who they use... there must be a "race" shop somewhere near.
Old Dec 3, 2003 | 10:20 AM
Strick's Avatar
Strick
Default Re: Flywheel balancing? (bogus)
You'd think as this is NASCAR country. :confused:
ZylaRace's Avatar
ZylaRace
Typically the whole rotating assy gets balanced. i.e. All seperate pices get balanced to each other. Trying to match one flywheel's balance to another,... Have not heard of this being done before. Could maybe do a static balance.
Old Dec 3, 2003 | 10:38 AM
Strick's Avatar
Strick
Default Re: Flywheel balancing? (ZylaRace)
This flywheel balancing is new to me, too. The Fidanza Co. lead me to believe it was a rotating balance similar to balancing a tire.
Old Dec 3, 2003 | 11:54 AM
ZylaRace's Avatar
ZylaRace
Yes, as an assy, not as seperate pieces.
Old Dec 3, 2003 | 11:58 AM
Strick's Avatar
Strick
So, I'm supposed to take out the engine to change over to an aluminum flywheel? I think I'll stay with the OEM dual mass.
Old Dec 3, 2003 | 01:41 PM
bogus's Avatar
bogus
As I understand it, you balance the new flywheel to match the balance of the existing flywheel...
it's a pain, but I have been told it can be done... I just don't know how.
Old Dec 3, 2003 | 03:36 PM
Strick's Avatar
Strick
I'll stay on it til I find the answer. Thanks guys. :cheers:
Old Dec 3, 2003 | 03:51 PM
rodj's Avatar
rodj
The assumption is that the OEM flywheel is not neutral balance ,as in it has a "inbalance" to neutralize the inbalance in the engine from the factory.
You have to get your new flywheel (which is probably neutral at the moment)
machined to duplicate this and maintain the overall neutral balance the factory set up.
All the shop has to do is spin your OEM flywheel up and note how far out it is at what point in relation to the crank dowel.Then machine your new one to the same setting.As stated ,just like balancing a tyre.
Old Dec 3, 2003 | 08:20 PM
Strick's Avatar
Strick
Default Re: Flywheel balancing? (rodj)
The cool thing about the Fidanza dual mass aluminum flywheel is you just add weights to match the OEM wheel. The problem is finding someone with the equipment to spin the wheels and calculate where to put the weights on the new flywheel.
Old Dec 4, 2003 | 06:43 AM
TreyZ28's Avatar
TreyZ28
The LT1 is internally balanced. Just get the flywheel nuetrally balanced. The only time a flywheel is not nuetral is when you motor is effed for its extenrally balanced :)
[Modified by TreyZ28, 6:44 AM 12/4/2003]
Old Dec 4, 2003 | 08:36 AM
Strick's Avatar
Strick
Default Re: Flywheel balancing? (TreyZ28)
Hey Trey, I think the LT1 is balanced at the factory by means of adding weights to the flywheel to balance the rotating mass of the engine. Like we said, like balancing a tire. Some of the guys here (on the CF) that have rebuilt their engines have gone to the internal balancing, hence, neutral flywheels. Thanks for the comeback, Trey. :thumbs:
Old Dec 4, 2003 | 09:00 AM
TreyZ28's Avatar
TreyZ28
I'm almost certain the LT1 is internaly balanced stock :confused:
just because it has a mass added to the flywheel does not meen its not nuetral.
At work, practically all of our driveshafts, cranks act have masses added to them (but then again, we are VERY VERY precise, more than the average car has to be)
My nuetrally balanced flexplate had a mass welded to it, both did and so did the stocker....
hopefully someone can give a difinitive answer :cheers:
[Modified by TreyZ28, 9:02 AM 12/4/2003]
Old Dec 4, 2003 | 12:14 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
The LT1 is most certainly NOT internally balanced. There is a counterweight on stock LT1 flywheels that is used for balancing. Generally when you get a new OEM flywheel you just make sure the weights are in the same place on the new flywheel.
FWIW, even if they say it is neutral balanced, it is most likely not. I had my "neutral balanced" setup from McCleod balanced and they had to take of 45 grams to get it truely "neutral" balanced. 10 grams was from the pressure plate.
There are shops that can match the balance of one flywheel to another so keep searching.
Old Dec 4, 2003 | 12:35 PM
tjwong's Avatar
tjwong
Yes it is easily done by any competent engine or machine shop. I have a machine shop here that can match balance any peice of equipment. Yes while it is good to balance everything as an assembly its not necessary if you are replacing one part of tha assembly. For instance the balancer on the front of the engine is nuetral balanced, it can be replaced with another unit that has been neutral balanced.
Now the flywheel is different it does have a counterweight on it, and if that isn't the same on your new flywheel its going to vibrate. If you take your old flywheel to amachine shop it can match balanced to the old flywheel, and your engine will be just as good as it was before.
Old Dec 4, 2003 | 12:38 PM
xs650's Avatar
xs650
Default Re: Flywheel balancing? (Vette92)
Any tips on how to determine if a shop can really do that right as opposed to just sying they can do it and taking on the work?
Why do they externally balance some engines?
To Flywheel balancing?
Old Dec 4, 2003 | 12:53 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: Flywheel balancing? (xs650)
It is cheaper to externally balance an engine.
Best thing to do is ask around locally to find out who is good and who to stay away from. Look to ask the small local engine builders as they usually give you a straight answer.
Old Dec 4, 2003 | 02:44 PM
Strick's Avatar
Strick
Great replies, guys Thank you very much :cheers: I'm currently calling around and even have a note into one of the NSACAR shops. I'll let you know how it comes out. :cheers:
Old Dec 4, 2003 | 09:37 PM
pablocruise's Avatar
pablocruise
It should be easy Strick. I ran into the same issues when switched to a single mass set-up. -although mine is a L98-
I took my flywheels to a nearby machine shop that has balancing capabilities. I said "Here, match this one to this one" The next day I had this:
They just matched the amount of weight of the DM and welded a mass onto the SM in the same location and drilled it till it was the same. Within grams. The motor shook hard without it
:eek: :crazy: :smash:
[Modified by 89 Paul in Cal, 6:40 PM 12/4/2003]
