Floppy ear sun visors
Old Dec 3, 2003 | 11:10 PM
gybonz's Avatar
gybonz
Cruising
Default Floppy ear sun visors
What's the deal with my sun visor extensions on our 96. Are they actually supposed to do anything ? Ready to cut off the lopped ears! :confused:
Old Dec 3, 2003 | 11:26 PM
Caboboy's Avatar
Caboboy
Default Re: Floppy ear sun visors (gybonz)
I seem to remember a post where the solution was to insert a fairly stiff wire in from the end of the visor.........sorry I can't be more specific.
I know I coulda' remembered more 15 or 20 years ago though :lol:
Old Dec 3, 2003 | 11:29 PM
Blown 96's Avatar
Blown 96
I have the same problem always wondered about that.
Old Dec 4, 2003 | 12:01 AM
sraft's Avatar
sraft
Default Re: Floppy ear sun visors (Blown 96)
I was curious also, so I took a set apart.
There's a masonite-like piece (~3/16" thick) that the is the main backbone of the visor. The bracket and mirror are mounted to this piece. This backbone is sandwhiched between two larger pieces of cardboard. On one end, the cardboerd is 3-4 inches longer than the masonite and forms the ear. The cardboard eventually tears and results in the floppy ears.
So, as others have posted, you can jam something in there to keep the ears from flopping, you can have the visors recovered for ~$50/pair, or you can try and repair/recover them on your own. If I end up redoing them myself, you can bet I'll substitute something a little more rugged than cardboard for support.
Old Dec 4, 2003 | 12:09 AM
Rex Ruby's Avatar
Rex Ruby
Philly 'Burbs Events Coordinator
Default Re: Floppy ear sun visors (sraft)
I opened a floppy disc, threw out the disc, trimmed each piece down, removed the mirror and side in the plastic. No more floppy ears :D :cheers:
Old Dec 4, 2003 | 01:11 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
My visor covering has finally disintegrated along the floppy ear edge so need to be recovered and rebuillt too...ah, a winter project.
I recall someone using a piece of heavy plastic instead of the cardboard to cover the masonite. Appaarently this solved the broken ear problem.
Old Dec 4, 2003 | 07:31 AM
Red Tornado's Avatar
Red Tornado
Default Re: Floppy ear sun visors (65Z01)
yup, same winter project for me as well. my drivers side visor also makes annoying noise due to some sound pellet-like item rolling around when i make any turns, drives me a little nutz :crazy:
Old Dec 4, 2003 | 09:42 AM
Micky Davis's Avatar
Micky Davis
Count me in on this one. Driver's side only but annoying as
the devil. I even folded mine up between the visor and roof
for a while to get it out of my face. I'm 6'1" so my view out
is immediately below the visor.
Have a good'un.............
Old Dec 4, 2003 | 11:37 AM
okinawa86vette's Avatar
okinawa86vette
Default Re: Floppy ear sun visors (Micky Davis)
I just got annoyed with it after taking the visors off of my '86 for the same problem and bought a new pair for my '88 from TLD. They were worth it since they were brand new GM pieces and of the updated late C4 style. They even had the airbag warning on them.
Chris
Old Dec 4, 2003 | 11:59 AM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Default Re: Floppy ear sun visors (okinawa86vette)
Whose TLD and how much did they set you back? Also, do they have a website? Thanks....
Old Dec 4, 2003 | 12:12 PM
Jeffmete's Avatar
Jeffmete
Default Re: Floppy ear sun visors (Caboboy)
I'm 6' 5", so I just took them off. Make a nice clean look on a convertible!
Old Dec 4, 2003 | 02:05 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
I'm 5' 5", so I just took them off. Make a nice clean look on a convertible!
Welllll, it's true.
If you do have to replace them, I purchased a set from Ecklers for my father's '88 for like 60 or 70 bucks each... much cheaper and just as nice as the OEM ones.
For now, I'll just leave mine with the clean shaven look. (ahhh, nevermind)
Mark
Old Dec 4, 2003 | 02:22 PM
okinawa86vette
Default Re: Floppy ear sun visors (C4 Newbie)
TLD is The Last Detail......their website is
http://www.tld-corvette.com/
I have had nothing but good luck with them. Their prices are very reasonable especially when compared to a lot of the other places out there. They list the repro visors for $75 each if yours has the lighted mirrors. Ecklers listed the lighted ones for $90 each.
Chris
[Modified by okinawa86vette, 1:23 PM 12/4/2003]
Old Dec 4, 2003 | 02:26 PM
tobijohn's Avatar
tobijohn
Bench Racer
Thanks for the info! :thumbs:
Old Dec 4, 2003 | 03:49 PM
RoadReady's Avatar
RoadReady
Default Re: Floppy ear sun visors (tobijohn)
Has any one tried the $6 kit that's been advertised on e-Bay? It's listed as
"84-96 Corvette Sagging Sunvisor Repair Insert" but provides no details.
Old Dec 4, 2003 | 03:58 PM
okinawa86vette
Default Re: Floppy ear sun visors (TenneC4)
I'd bet it's probably one of those deals like the $15 t/b bypass kit when you can go down to autozone and pick up a pair of hose clamps and a hose adapter for 3 bucks. But I don't know anyone that's tried the visor repair one.
Chris
Old Dec 4, 2003 | 04:05 PM
tobijohn's Avatar
tobijohn
Bench Racer
You're probably right but if no one has any feedback on it, for the common good of all C4 owners here I'm willing to order one and check it out....
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2446397573
[Modified by tobijohn, 4:07 PM 12/4/2003]
To Floppy ear sun visors
Old Dec 4, 2003 | 07:48 PM
okinawa86vette
For 6 bucks, even if it doesn't work, it might be worth trying in case it does. My visors were shot though, not just sagging, but the 16 years of use made them pretty rough looking.
Be sure to post how it turns out. It looks like it might be a stiff piece of material that slides into the visor through the hole that the metal rod goes into.
Chris
Old Dec 4, 2003 | 09:03 PM
tobijohn's Avatar
tobijohn
Bench Racer
Well, if we don't here from anyone on this by tomorrow, I'll go ahead and order it...
Old Dec 4, 2003 | 10:17 PM
white90conv's Avatar
white90conv
I was able to solve the floppy ear problem by inserting a piece of hacksaw blade. I inserted it through a hole in the cover where the metal support bar enters the visor. I pushed the piece of blade into position and then put in some glue (liquid nails) to hold it in place. This solved the floppy ear problem but I eventually decided the visors were a bit tacky looking and bought new ones from TLD.
